Previous in Forum: About Standards for Testing Product.   Next in Forum: Hot-Dipped Metal Bands in China?
Formation of Hydrogen in Fume Duct
03/10/2008 12:07 PM
If moisture / accumulated water is exposed to high temperature fumes from steel making process, containing dust of iron / iron oxides besides O2, N2 (major), CO2, SO2 etc., is it possible that gaseous hydrogen can form due to dissociation of water / moisture?
If yes, is there a threshold temperature of the waste gases for hydrogen formation?
Re: Formation of Hydrogen in Fume Duct
03/10/2008 6:16 PM
I may not be the one to answer this question; but I would think you would have more problems with the formation of Sulfurous acid (H2SO3), and Sulfuric acid (H2SO4).
03/11/2008 4:41 AM
http://en.wikipedia.org/wiki/Autoignition_temperature gives the autoignition temperature of free hydrogen gas in air as 571degC. So if the temperature is above this, as is likely to be the case during parts of the steel-making process, then any hydrogen present will be in its combined form with oxygen, i.e. water/steam.
Good Answers: 109
03/11/2008 1:40 PM
Hi,
you are absolutely right:
any corrosion of iron will produce hydrogen!
From Fe and 2 H2O is generated Fe(OH)2 the dark green coloured iron hydroxide.
This in turn will be oxidised to a mixture of Fe-OOH and Fe(OH)3 if there is enough oxygen available. At higher temperatures Fe2O3 and Fe3O4 are resulting by treatment of iron with hot (500 to 600°C) steam.
Any of these reactions will strip a fraction or all hydrogen from the water molecule and let it go somewhere: sometimes quite dangerous.
There was a near failure of a big suspended bridge (1.6km long) crossing the harbour of Hamburg, Germany because the suspension steel wires were encapsulated good enough to keep some hydrogen inside the encapsulation and not good enough to hold the moisture out completely.
So the small amount of hydrogen caused hydrogen embrittlement to the high strength highly stressed wires. As this was detected half of the wires were broken, some months later the bridge would have shown a spectacular collapse.
For a fast generation of hydrogen its better to use iron and sulfuric acid.
RHABE
Kilowatt0 (1); PWSlack (1); RHABE (1)
