Previous in Forum: Pollution Control   Next in Forum: chemical
10 comments
Solution/Glue for Stainless Steel Hinge
03/13/2008 7:54 AM
Hi! I need some help regarding the stainless steel hinges. Can any body tell me what kind of solution or glue is used for for smooth and slow motion in hinges?
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Solution/Glue for stainless steel hinge
03/13/2008 8:18 AM
This stuff will make them go pretty slowly:
I'm banging them out for 50p a tube. How many do you want? <Wheeze>.
Essex jobs for Essex yobs! <Burp>.
Good Answers: 143
03/13/2008 8:31 AM
Please tell us what you want the hinge to do. I don't think you really want to glue it - that's the sort of thing you do to the hinges on Stinky Pete's liquor cabinet!
03/13/2008 9:32 AM
In your dreams....<Slputter>
03/13/2008 9:53 AM
Glue it thats what stinky pete would do? I want the hinge to have the regular smooth motion like bearing hinges. I have seen the stainless steel hinges having some material between the hinge sides and the rod inserted in them which makes their movement pretty regular even under load.
03/13/2008 12:10 PM
Well, why did you ask for glue, and why didn't you say that you'd sussed it out already? I'm left with a large amount of SuperGlue that no-one wants! <Wheeze>.
Good Answers: 266
Re: Solution/Glue for Stainless Steel Hinge
03/13/2008 10:21 AM
Thermo plastic thrust bearings. Manufactures use different materials as a bearing. Nylon, UHMW-PE, Delrin are some.
03/13/2008 12:33 PM
Some cabinet doors use either a stroke-dashpot to slow down the opening/closing, or a bumper-dashpot to slow down the final closing action. These people can help:
http://www.screwfix.com/ (usual disclaimer).
Good Answers: 183
03/13/2008 7:06 PM
try IGUS bushings look at google for address
03/14/2008 9:02 AM
Turntables used a product on the tone arm lifting device called damping fluid. That is what allowed the tone arm to set down gently. Of course you were only dealing with about a half a gram. High end audio shops should carry it or this is what a google search provided. I hope this helps.
I know the rumour is true. I started it and I don't think I would lie.
Good Answers: 123
03/14/2008 11:33 AM
As is common in this forum we need more information. There is some reason there is a stainless steel hinge used. From the information we have, we cannot tell if we would need tweezers or a fork lift to assemble the hinge. Please, more information.
Bob
Anonymous Poster (1); bob c (1); nick name (1); ozzb (1); Pebbles (1); PWSlack (1); Stinky Pete (3); TVP45 (1)
You might be interested in: Industrial Hinges, Plywood, Door Stays and Lid Stays
