Previous in Forum: Diesel Engine Intake Air Temperature.   Next in Forum: Parameters for 15mw Steam Turbine
Thermodynamic Losses in Prds
03/14/2008 5:29 AM
I am trying to depressurise and desuperheat steam from 176bar, 540deg C of approx flow 180t/h to 105bar, 515deg C. This is done to condition the steam parameter suitable for the inlet of a Steam Turbine. I need to evaluate the loss as a result of this depressurising and desuperheating. How is it done?
GVK
Re: Thermodynamic losses in prds
03/14/2008 5:58 AM
At 176bar,540 deg C, the enthalpy is h=3392.32 kJ/kg.
At 105bar,515 dec C, the enthalpy is h=3406.80 kJ/kg.
The change in enthalpy is -14.48 kJ/kg; 735 kW (14.48 kJ/kg * 180 tons/hr)
03/14/2008 6:16 AM
From steam tables:
  • h(180barg, 500degC) = 3268kJ/kg
  • h(180barg, 600degC) = 3555kJ/kg
  • h(170barg, 500degC) = 3281kJ/kg
  • h(170barg, 600degC) = 3564kJ/kg.
Interpolating, the start condition is: h(176bar, 540degC) ≈ 3387kJ/kg.
Steam at all the above temperatures and pressures is superheated.
From steam tables:
  • h(110barg, 600degC) = 3616kJ/kg
  • h(110barg, 500degC) = 3360kJ/kg
  • h(100barg, 600degC) = 3624kJ/kg
  • h(100barg, 500degC) = 3373kJ/kg
Interpolating, the end condition is: h(105bar, 515degC) ≈ 3404kJ/kg.
So energy needs to be added to get it to this condition: 3404-3387=17kJ/kg. It cannot get there by adiabatic expansion. At these end conditions, the steam is still superheated.
Er, around 800kW is needed.
03/16/2008 11:59 PM
Thanks. got the idea, shall continue from here.
GVK
03/17/2008 12:48 AM
From the calculation which is shown and according to what i did, its not evident that there is a loss of energy from inlet to outlet condition, as the specific enthalpy is increasing. Its obvious that the depressurising and detempering is a thermodynamic loss. Is there a method to show this loss.
GVK
03/17/2008 6:07 AM
Yes. Calculations based on the data in Steam Tables!
Re: Thermodynamic Losses in Prds
08/14/2011 1:25 PM
Dear Mr. Gautamkum,
As I nderstand from Your Question, IT is NOT CLEAR or defined correctly. You have referred " I need to evaluate the loss as a result of this depressurising and desuperheating,"
Which loss you want to evaluate.? What is the Temperature of De-Superheating water used.?
As already explained by other CR4 MEMBERS, the Difference in ENTHALPY/Kg. of Steam can be found out before de-superheating and after de-superheating and this quantity to be multiplied by 180x1000 Kgs. and this heat will be absorbed by the de-super heating water pumped/sprayed and the total quantity of de-superheated steam , will be obviously more.
Neglecting the RADIATION LOSSES (for discussions purpose) where is the question of "loss" that is to be estimated.?
Pl. clarify
RAJESWARI.
Register to Reply 6 comments
gautamkum (2); PWSlack (2); rajeswari (1); Solrac (1)
