Previous in Forum: Testing for Mechanical Properties of Cementious Products   Next in Forum: Submerged Orifice with No Change in Head?
Grit Flow Rate for Pump Sizing
03/14/2008 10:04 PM
I am trying to size grit pumps for an aerated grit chamber. I keep coming across values of grit in cubic feet per million gallons however, I cannot determine whether that includes the water that you would pump with the grit or the dewatered grit and I am unaware of what would be considered normal practive for grit quantities.
Additionally, what % solids is pumped grit + water typically?
Pathfinder Tags: headworks grit pump
Re: Grit Flow Rate for Pump Sizing
03/14/2008 11:39 PM
Hi Melanie,
I would think that the grit values are: (ft3 of dewatered grit)/(gal of water "carrying" the grit). This is an ASSUMPTION, one of you CivE's out there correct me if I'm wrong!
For % solids:
Let's assume that the dewatered grit (still moist) is 70% grit and 30% water BY VOLUME.
This means that the gallons of DRY GRIT = (0.7)(7.481 gal/ft3)(ft3 of dewatered grit)
The % solids (by VOLUME) = 100 x (gallons of DRY GRIT)/(gallons of water "carrying" the grit).
Example:
Grit value = 1000 ft3 of Grit/1,000,000 gal H2O
Gallons of DRY GRIT = (0.7)(7.481 gal/ft3)(1000 ft3 of dewatered grit) = 5236.7
% solids (volume) = (100)(5236.7 gal DRY GRIT)/(1,000,000 gal H2O) = 0.52%
Hope this helps,
Mike
