Previous in Forum: Grit Flow Rate for Pump Sizing   Next in Forum: Stadium's Foundation
8 comments
Submerged Orifice with No Change in Head?
03/14/2008 10:10 PM
In what circumstance would you find water flowing through a submerged orifice without have a change in elevation head from one side to the other?
Pathfinder Tags: submerged orifice flowrate
Re: Submerged Orifice with No Change in Head?
03/14/2008 11:10 PM
Hi Melanie,
I am having trouble understanding your question. Do you mean that the submerged orifice is between two separate tanks; and that both tank levels are the same?
Please describe carefully the situation. Do NOT be afraid to give too much information! The more detail, the better chance you have of getting a decent answer.
Mike
03/15/2008 4:15 AM
It's a matter of definition, a 'head' is just a pressure difference. Thus any pressure difference will do, it could be generated by a pump, or the rotation of the earth or the pull of the moon. Once a flow is established the water will of course have considerable momentum, and may appear to be flowing despite little or no head.
How much 'head' is there in the lower reaches of the Mississippi?
03/15/2008 11:24 PM
This sounds almost like a riddle,
if the apparent initial "head" is equal, then the flow could be caused by a difference in density of the fluids on both sides of the orifice, which would be a temporary condition until equalizing, depending upon the volumes this may take considerable time. The density is of course affected by temperature, atmospheric pressure, bubbles thru one of the liquids, ...
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
Good Answers: 11
03/16/2008 7:13 AM
Heavy water on one side.
horsepower measures work, ponypower measures pleasure!
Good Answers: 18
03/16/2008 9:08 PM
Generally, you will not have flow through such an orifice or pipe unless you provided another source of pressure drop across said orifice or pipe.
03/17/2008 4:46 AM
Is this a homework question?
03/17/2008 4:21 PM
Water moves through an orifice when there is a energy grade difference. Three components make up the energy grade for the water on each side of the orifice, Pressure, Elevation, Velocity. A difference across the orifice in any of these could allow water to move through the orifice. Additionally other factors such as diffusion allows water the move across an orifice (in both directions) as the two fuilds equilibrate differences in the properties of each fluid (i.e. chemical or thermal gradients).
03/20/2008 10:48 AM
The most likely answer is temperature difference.
Register to Reply 8 comments
agua_doc (1); Anonymous Poster (2); CoronaCameraMan (1); Mikerho (1); RCE (1); saddlechariot (1); user-deleted-1105 (1)
You might be interested in: Steam Traps, Captive Screws, Rheometers
