Previous in Forum: electrical   Next in Forum: Cable ampacity and voltage drop
Variable Resistor
03/17/2008 12:52 PM
I want to check the variable resistor with the multimeter. How can i check it?
Re: Variable Resistor
03/17/2008 3:41 PM
Use the ohms range?
03/17/2008 4:28 PM
It depends on if it's in a circuit or not, if it's not, ohm it out. Turn it from min to max and see if it does those resistances. If it does, it works, if it doesn't it doesn't work. If it's in a circuit you'll have to check the voltage drop across it. Depending on how accurate you need it you may have to find out what kind of current it has coming out and use Ohm's Law to find out what resistance you have.
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
