Previous in Forum: Improvement of a Company / Outlook   Next in Forum: Foreign Trade Manager
Caustic strength issue!
03/17/2008 2:31 PM
What happens when the caustic strength abnormality is experiencing at bottle washing machine?
samuel
Re: caustic strenght issue!
03/17/2008 2:43 PM
kolawole gbenga
Not quite sure what you mean, do you mean your ph increases/decrease during wash with out adding or nuetralizing the caustic.
if so, may have an outside source contributing to that.
phoenix911
Good Answers: 101
Re: Caustic strength issue!
03/17/2008 11:33 PM
Do you have a pH sensor and a dosing system to regulate your caustic level? If so, you may need to calibrate your sensor or check your dosing system.
Register to Reply 2 comments
