Previous in Forum: Automatic Bend Machine for bolts   Next in Forum: Pre-heating of water
Hydraulic fluid power.
03/17/2008 6:22 PM
I want copy of
ISO 3019-1:2001
Hydraulic fluid power. Dimensions and identification code for mounting flanges and shaft ends of displacement pumps and motors. Inch series shown in metric units
This part of ISO 3019 specifies sizes and dimensions and establishes an identification code for the two- and four-bolt mounting flanges and the shaft ends of positive-displacement, rotary hydraulic fluid power pumps and motors. It is applicable to cylindrical keyed shaft ends with an external thread, as well as to those without a thread, to conical keyed shaft ends with an external thread and to 30 � involute spline shaft ends. This title may contain less than 24 pages of technical content.
Pathfinder Tags: Hydraulic fluid power.
This discussion was "closed" on 03/18/2008 4:18 PM. No new comments are allowed.
Good Answers: 66
Re: Hydraulic fluid power.
03/17/2008 6:26 PM
Available for purchase here.
Aequam memento rebus in arduis servare mentem.
Good Answers: 183
03/17/2008 8:23 PM
look in the pump catalogues of european manufacturers as Rexroth or Bosch or other theyrespect the ISO/DIN norms so that their shafts have the dimensions you try to find as well the flanges.
Friend of CR4
03/18/2008 4:18 PM
There's no free ride here. You need to contact the ISO to purchase this standard, or buy it from a licensed dealer like IHS or TechStreet.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Register to Reply 3 comments
Chris Leonard (1); CSM Engineer (1); nick name (1)
