Previous in Forum: Audio Watermarking---HELP Needed?   Next in Forum: PDF Converter
Flashing an ECU
03/18/2008 12:43 PM
I am looking for a source, class, book, program and compiler to flash various ECU's for Fords, GM's, KIA's. Need to flash the ECU to accommodate a lean reading. So I have to be able manipulate PROM files to reset timing, A/F mixtures, fuel rail pressures, MAF values, crank position, trottle body position, etc. Any knowlegble responses would be appreciated. The vehicles I am working on are 1996 and later with OBll computer. Thanks
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: Flashing an ECU
03/18/2008 1:13 PM
Vapster,
Check with a local dealership. The Ford dealership I worked for in '92 had a machine to reprogram those.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
