Previous in Forum: Tea Break Challenge 2   Next in Forum: Electrical Wiring Question
24 comments
percussion suppresion
03/20/2008 8:56 AM
hello problem solvers
i am trying to find a way of percussion-proofing a small stage
in a restaraunt that would feature flamenco dancers
problem is the stage is upstairs and the people underneath the stage
do not enjoy a quiet meal due to the pounding above them
no. the stage cannot be moved downstairs
i would like to apply the same solution to the floor in the reharsal space of the dancers. any ideas??????????????
Pathfinder Tags: earthman
Good Answers: 143
Re: percussion suppresion
03/20/2008 10:12 AM
I don't think you can apply it, but...
2.5" x 4" x 4" blocks of rock maple turned on end, floated in 1" of New Jersey yellow clay (similar to baseball infield "dirt") on top of a 6" concrete slab. It will absolutely work. Now, as for anything remotely practical, well...
03/20/2008 10:39 AM
owww
Popular Science - Cosmology - New Member United States - Member - New Member
03/20/2008 10:48 PM
LOL!!!
All worthwhile programmers know that constants always vary.
04/03/2008 8:59 PM
sounds like bowling alley material.
Good Answers: 918
03/20/2008 11:05 AM
You have two courses of action.
1. Raise the floor upstairs so that it "floats over the original floor.
2. Lower the ceiling downstairs so that it floats under the original ceiling.
A third option is to offer special dining rates to the deaf!
In cases 1 and 2 you are acoustically isolating the two rooms with barriers that will not interact with each other. However, the space between the two must be filled with a sound absorbent material like fiberglass to dampen higher frequencies.
Right now when sound strikes the upstairs floor it will vibrate like a speaker cone. Since the ceiling downstairs is mechanically coupled to the upstairs floor via the floor joists, the ceiling simply is the back side of that virtual speaker cone.
The trick is to decouple the two mechanically and add sound deadening material between them to absorb any sound that echoes between them. If you don't it will be like a double sides drum and will not get the desired results.
You will probably need an architect to do this since it is a public building and will no doubt require a building permit. I would recommend finding an architect that specializes in acoustics and sound stages or has access to someone that specializes in this field.
I have worked on a few recording studios that employ these techniques (and a few others) and the amount of sound dampening between rooms will amaze you. Done right the downstairs may not even be aware of the upstairs!
03/20/2008 12:00 PM
thank you for your replies
this is a case of no budget and lots of love for the art form
i know about sound isolation
the sand box idea is interesting
i was hoping i could find something like a hydraulic set of feet that perhaps absorbs
the blow.or at least something that could minimize the percussion transfer to the
floor.
03/20/2008 10:47 PM
Here's a better solution. Add a third floor so that dancers, etc, are isolated from first floor by an entire floor. LARGE air gap = sound suppression. Of course, cost may be a slight issue.
Good Answers: 266
03/20/2008 12:41 PM
Instead of raising the floor. Place insulating barrier on the floor you have and place another floor above it. Check to be sure the stage can handle the additional weight.
03/20/2008 11:45 PM
I have no Idea if this would work. Could you suspend the small stage from the ceiling as it would float above the floor and not transmit vibration to the room below.
Re: percussion suppression
03/21/2008 12:07 AM
Good idea BigEdm.
How about this. From a practical standpoint, we have an upstairs (dancers) and a downstairs (diners). Now, how shall we separate them? First by distance (not the best solution in this situation), then by soundproofing- foam, alternate rafter separation, etc,.) not really the best idea either. So, what's left? We could use your idea and suspend the stage by cables, etc. (not, at all, practical). Or we could use the idea I suggested earlier by separating the dancers from the diners by an intervening floor (lots of sound absorbing airspace). Now, if there's not a third floor to work with, do we have a basement for the a) diners, or b) for the dancers?
IMHO your situation is best resolved by distance.
-John
03/21/2008 12:32 AM
How about diners on second floor, dancers on the first floor.
Ed
03/21/2008 8:47 AM
ok
thanks guys
all your ideas would work
so far
after comment # 1
i recalled a friend who told me they made a huge sandbox to prevent vibration
while shooting holograms
so that idea , in conjunction with a dead weight and a floating stage
uh huh
im still thinking
although im going to go back to my original thought
is there small hydraulic shock absorbers that can also be apllied like feet under the
stage ?????????
and . . . no i cannot go downstairs
it is the upstairs that is being offered as a venue if we can figure out how to
minimize the sound that would disturb the people directly bellow
think , someone hammering a nail into the floor directly over your head
its not so much the high end sound were concerned with
its just the "direct" percussion sound directly under the stage area downstairs
thanks
03/21/2008 12:11 PM
Here is my favorite vibration isolation product:
http://www.fabreeka.de/index.htm
You may well be able to design a raised dance floor that is isolated from the floor of the second story. The problem is you have two modes of coupling of the dance energy. The first is the direct vibration, the feet stomp the floor, the floor vibrates, the ceiling below vibrates, and the diners are bothered. This can be helped with isolation.
The second energy coupling mechanism is acoustic. The feet stomp the impact generates sound, the sound couples into the walls, floors, and ceiling, piping and ducting of the second floor, which transmits that energy to the first floor. You will not be able to solve that with isolation. You only solve that by putting tennis shoes on the dancers which defeats the purpos of flamenco...
I really don't see this problem being solved without some serious engineering modifications to the building. I would suggest that even if you moved the diners upstairs and the dancers down stairs that it would still be a problem.
The only solution I am afraid is to stop the dancing, or stop the dining, or find diners that appriciate the dancing...
Where are you located? I would be interested in having a look to see if I can dream up a solution to the problem, but it will be pretty hard to do via the interenet. I also may be able to refer you to someone in your area. The noise and vibration field is pretty small and tight knit.
03/21/2008 1:06 PM
toronto canada
thanks for offering
ok so far im thinking
sound blanket
sand bags around the bottom perimiter , to elevate the stage and deaden the sound
sound blanket on stage
sheets of half inch ply double laminated together the size of the stage
floating on top of the sound blanket
mike the footwork
it kind of incorporates everything suggested exept suspension
were not too concerned with the building vibration
there is piped music downstairs and the loud talking helps
( ohh. .... any knowledge of a good surface that will suvive this onslought of
footwork?? generally people just use ply or whats available, so maybe theres a
product out there that is perfectly suited to this craft)
thanks guys
i wont get to try this project for at least about a month so this is really
helping to hone down my approach
03/21/2008 4:02 PM
By the way, you need to be concerned with building vibration, since any part of the building that vibrates will cause air to move, and that is sound...
Are you open for dinner? I am always looking for somewhere new to have dinner...
04/03/2008 8:07 PM
hi steve
its not my restarauaunt
but if you let me know when you would like to try tapas etc;
i will set up a table
just leave me your info
eartmanindia@yahoo.com
04/03/2008 8:49 PM
My business in Toronto got moved to the week of April 21st...
I still hope to stop by for dinner.
Good Answers: 128
03/22/2008 3:08 PM
Guest,
If you can have the dancing area a few inches above the building's floor surface, try either of these two ideas. Both of them use the approach of isolating the dancing surface from the building's actual floor to minimize conducted noise and loose insulation to minimize air transmission of noise.
1. Build a fairly stiff raised framework with 2x4's on 24" centers and a second layer of 2x4's laying flat-ways, on 24" centers the cross-wise direction. Support the lower 2x4's on leaf springs spaced on 4-foot centers. Use springs that are rigid enough to only allow about 1/4" of deflection when loaded with 600#. The ends of the leaf springs would be attached to the actual floor surface with rubber vibration isolation pads under them. Edge the raised framework with lumber and a flexible fabric or plastic which would dress its exposed side. Cover the building's floor surface with fiberglass insulation or 2-3 inches of loosely blown in cellulose fiber insulation. Finish the top of the raised floor framework with 3/4" tongue & groove plywood and a finish layer of thin engineered wood flooring so the dancers have a good surface for their feet. This will give you a solid surface only about 7" above the building's floor and provide very good isolation of the mid to lower frequency sounds caused by the stamping of the feet. It will also be stable and free of unwanted vibration. If there is too much oscillation of the dance surface, you could add shock absorbers.
2. Do the same as above, but instead of using leaf springs use inner tubes in the 24" x 24" square areas. If they are not thick enough to keep the dancing surface floating above the building floor, you could add 1" or 2" thick pads of fire resistant foam under the inner tubes. This will probably give greater sound isolation than the method above. It will have more motion both vertically and side-to-side. If the side-to-side motion is too great, you might have to add guides or cables to help.
--John M.
03/22/2008 3:42 PM
Sounds a little too elaborate for me. I sincerely believe if Yanis will just build a simple sandbox the size of the stage (slightly larger) with retaining walls to keep the sand from moving away under the weight of dead load + live load (anticipated dancers). Make the sand, perhaps, 12 inches or so thick.
Some modifications may be required in order to make it practical however. I go with KISS in this case.
I think it may very well work, and, the expense will be minimal.
-John
Good Answers: 128
03/22/2008 3:51 PM
Johnjohn,
Perhaps it is more elaborate, but I am concerned with the practical areas of weight and elevation. The 12 inches of sand with dancers on top probably exceeds the allowable dead load and live load limits of the structure.
--JMM
03/22/2008 4:58 PM
Good point. But I think maybe if a steel I-beam frame were used for the sandbox, it could be extended out to load bearing structures (walls, etc.) to distribute the load evenly. I guess what I'm saying is to support the sandbox on either steel I-beams or even engineered lumber joists. The main point is that sand is probably the best sound dampening material for this application. Of course some specific engineering calculations would certainly be in order, etc. Think back to spring break when you danced on the pavillion on the beach. Maybe it wasn't a sound problem because
a) Everyone was loaded.
b) Everyone was barefoot.
c) Anyone within earshot didn't give a damn anyway.
JMHO anyway.
03/21/2008 3:20 PM
I'll be in Toronto the week of April 7. If you wish I would be happy to have a look at it. Drop me a private message by clicking on my screen name a selecting message if you wish...
03/21/2008 3:53 PM
hey steve
im right downtown
bathurst and queen
the Segovia Restaurant is at young and wellesley
im at 416 504 1642
03/23/2008 7:20 AM
re the sand
i was considering making a channel around the perimiter of the stage
then i place sandbags ,used in film, in the corners and every two feet
(these are the sandbags with the industrial strength ruberiized coating )
butttttt ...... now im beginning to like the rubber tube idea in terms of weight and
soundproofiness
my unsureness would be in the stabillity and level surface
Register to Reply 24 comments
Anonymous Hero (1); Anonymous Poster (7); BigEdm (2); jmueller (2); Johnjohn (5); ozzb (1); phoenix911 (1); Steve S. (4); TVP45 (1)
