Previous in Forum: Robotic Dog   Next in Forum: Steam
10 comments
Chain Saw Regulation
03/25/2008 8:19 AM
HI all
WE need to use chain saw in our company but i was advised that the saws should be serviced / overhauled by a qualified mechanic before we use them......
is there any body have any idea is that true and where we can check about that
I tried OSHA 29 CFR 1910.266 but it was not helpful
thank you for your time
An Engineer Creats the World that which never was. Theodore Van Karme
Re: Chain Saw Regulation
03/25/2008 9:42 AM
What is senior management's policy on the subject? What happens if someone sharpening it from the 'we' gets it seriously wrong?
There are liability aspects to consider, as chainsaws are potentially lethal devices. If the 'we' buys-in the service from someone else who is appropriately qualified, then a measure of indemnity and protection is provided to the 'we', as there will be records of the transaction.
So it depends upon the nature and strength of the health and safety recommendations in the locality of the 'we' and the structure in which the 'we' operates.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
03/25/2008 9:58 AM
Good points, best to just buy new blades, they cost about $20. I never sharpen them anymore, very time consuming. Nothing is more important than a sharp blade. Dull blades don't cut, and can kick back, and remove your face.
Probably a better idea is to hire professionals, let them do your chainsaw work for you. Using a chainsaw is fun, for about the first 5 minutes. Then, it's just really hard work. Better yet, let the senior manager give it a try. See how long it takes to hire someone then.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 73
03/25/2008 9:46 AM
If it starts, you're fine. The most important thing is to keep the blade sharp, and make sure you have the proper gas/2 cycle oil mixture. Bad things happen with a dull blade. Wear safety glasses, gloves, heavy clothing. I use one all the time, and haven't cut a limb off, yet.
03/25/2008 10:04 AM
Operating a chainsaw in the USA you don't need protective gloves or sleeves...as you have the right to 'bare arms' (baaad joke ...sorry)
Good Answers: 73
03/25/2008 10:13 AM
Del, Del, Del, you have reached a new low. I expect more out of silly guys than that. I think you should come to my house and slice up several cords of oak, with you bare arms. Bring Vermin with you, he can stack it. I'll provide the beer.
Good Answers: 38
03/25/2008 10:25 AM
The employees "trained" to operate them should go through a check list daily before they even attempt to use them. If something is not right right (chain brake does not operate, protective device loose or missing, gas leak, etc.) should be removed from service, tagged to describe problem, and fixed by a qualified technician or reputable service center. Sharp chains, correct gas/oil mixture should be part responsibility of the user but can be controlled by a responsible person in the facility to make sure enough of each is on hand for necessary replacement or consumption. Operators know best when something is not right because they use these devices daily. Untrained people should not be allowed to use something as capable of injuring themselves or others. They are responsible for the safe operation of the tool. You are responsible for providing a safe and reliable tool for their use as well as proper training.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
03/25/2008 12:20 PM
what about when we first have the saw
before we start working with the saw do we need a certified mechanic to inspect it and prove it works properly ?
03/25/2008 12:25 PM
<.....what about when we first have the saw......before we start working with the saw do we need a certified mechanic to inspect it and prove it works properly....>
If it's under Warranty, let the supplier demonstrate it before accepting it for use.
Let the 'we' check with its insurance company that its employees are covered for using it. Take the advice of the insurance assessor, for indemnity reasons.
Good Answers: 266
03/25/2008 2:04 PM
Yellow pages under saw sharping. Local Stihl dealer.
All so as that you are asking these questions you or the others of your company have limited use of this tool. Seek professional training as well these tools are very dangerous.
Good Answers: 97
03/26/2008 12:05 AM
billybolbol,
You are on the right track these references may help you focus...WE:
www.redcross.org/pubs/dspubs/chainsaw.pdf
www.cdc.gov/nasd/docs/d001201/-d001300/d001289/d001289.html
www.edis.ifas.ufl.edu/ae186
later days
Register to Reply 10 comments
billybolbol (1); Bricktop (3); bwire (1); charsley99 (1); ozzb (1); PWSlack (2); user-deleted-1105 (1)
You might be interested in: Saw Blades, Leaf Chain, Plastic and Metal Chain
