Previous in Forum: Pole Loading Analysis Software   Next in Forum: Micro crystals
EHV and HV transformer size
03/27/2008 5:25 AM
Can any one tell the ratings of Power Transformes, and ICTs
(a) 400/220 kV
(b)400/220/33 kV
(c) 400/220/132 kV
(d) 220/132/11 kV
(e) 220/132/33 kV
(f) 220/132 kV
(g) 220/33 kV
Re: EHV and HV transformer size
03/27/2008 6:47 AM
Not from those figures. Units of kW and MW would be needed.
Reply Score 1 for Off Topic
03/27/2008 11:45 PM
Refer to IEC 60076 or some standard trafo manufacturer.
BNDas
10/23/2009 4:53 AM
Standard : IEC 600076
Capacity: 100 MVA
Type of cooling : ONAF
Email: karunasarma@gmail.com
Engineering Fields - Energy Engineering - New Member India - Member - Jack of all trades
03/28/2008 1:22 AM
Power transformer rating is not a function of the voltage level, instead, the amount of power needed to be evacuated/transmitted shall be the determing factor for transformer rating. Which in turn, depends upon the installed capacity of generating station.
Generally, there are three levels of a power system network -
1. Transmission - Normally at EHV voltage levels
2. Subtransmission - Normally at HV/MV levels
3. Distribution - MV/LV levels
Finally, after stepping down the voltage, power supply is connected to consumer premises through cable etc in case of LV consumers, whereas for bulk consumers, power supply is given at higher voltage level(s) to consumer's grid substation.
The rating of transformers may vary from 11 KV, 25 KVA to say.. 400 KV, 500 MVA depending upon manufacturer.
As righly pointed out by Mr. B.N. Das, you can refer the IEC standard and for specific information regarding the capacities of transformers meant for various voltage levels, contact manufacturers.
It takes considerable knowledge just to reaIise your own extent of ignorance.
Anonymous Poster (2); biswanath.das (1); j_kamal (1)
