Previous in Forum: UV Absorption   Next in Forum: LED replacement for florescent T8 60W
16 comments
Solar Powered Swimming Pool Pump Motor
03/27/2008 8:49 AM
Anyone know of a web site or suggestions on setting up a solar power for a swimming pool pump (240v at 7 amp)? I have seen designs for solar heating of pool water. I was looking for something simple like a solar aray, storage battery and manual switch to cut back to commercial power.
Re: Solar Powered Swimming Pool Pump Motor
03/27/2008 10:14 AM
Hmmm......
240V @ 7A is 1680W.
Say the inverter is 80% efficient, that makes it, er, 2100W.
Taking the strength of sunlight as 800W/m2 typical on a good day and the collection efficiency of a solar panel as 5% (other efficiencies are available), then, er, one needs around 53m2 of solar panel to provide the grunt.
Er, what's the surface area of this pool? Dum, de, dum.......
Er, could non-electrical circulation techniques, like thermosyphoning, provide the flowrate required?
Just a few thoughts.......
03/27/2008 7:29 PM
Run a pipe from the shallow end to the deep end... the water will run down hill
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
03/28/2008 6:16 AM
why would you convert solar power into electric first before turn into heat? convert it straight into heat instead and use electric/gas boosting accordingly.
the solar water heating elements are not very efficient either but i guess better than the electric ones. you could design your own solar water-panel/s and placing them in a vacuum sealed box that sould idealy make it work well in cold also, i am talking about the primary circuit.
it does get complicated a little but in the long run should pay itself off.
Making mistake is part of learning.
01/13/2011 8:30 AM
Hi Some food for thought,
Have you ever heard about a solor pump which work from DC, you dont need a inverter. Why would you want the pool pump to be on battery backup?
03/27/2008 7:30 PM
But seriously folks...It would be more efficient to use solar power to heat the water and regular electricity (or wind generated electricity?) to pump it.
Good Answers: 101
03/27/2008 11:08 PM
Say, doesn't KrisDelTM manufacture an over-unity solar water heater cum pump? I think this guy's looking for a quote.
03/28/2008 3:46 AM
We're sold out...an production has stalled waiting for monopole magnets to come in from the Arctic and Antarctic...(we have to keep 'em at opposite ends of the stores). I think the penguins have gone on strike .
We may have to bring in some Elephants to keep 'em in order....
03/28/2008 9:46 AM
But if he would just install the solar water heater below the pool, wouldn't natural convection circulate the water without a pump?
OpMan
03/28/2008 9:52 AM
Yeh, there would be some convection but nowhere near the flow you get from a 1.5kw pump.
Maybe build a loooong thin pool on a North South axis and use the Coriolis force?
Hobbies - Target Shooting - New Member Hobbies - Model Rocketry - New Member Safety - ESD - New Member
03/27/2008 11:19 PM
I think you are looking for a circulating pump for your pool, for cleaning correct. If so try these sites, if they don't work let me know or if it is not what you need. I could probably head you in the right direction
eta engineering solar pool pump
ABC solar pool pump
03/30/2008 9:23 AM
There are many sources for a system to put in place. there are DC powered pumps up to 1 1/2 HP and it take approximately 3 panel to power it and create back up power. also you can get an inverter and be tied into the grid just in case. There are many many sites out there that I have found just googleing the topic. I have future plans of building a pool and found it will take about 4,000.00 to do this. if I save 100.00 or more per month in Texas then it would take 20 months to regain my investment because you can get a 2,000.00 rebate from fed gov.
03/31/2008 8:49 AM
JUST WHAT I WAS LOOKING FOR. THANKS.
Hobbies - CNC - New Member Hobbies - Musician - New Member
03/28/2008 5:51 AM
Try to target agricultural stores (farming). In South Africa they are a dime a dozen, look for solar powered bore hole pumps. They have backup batteries working on lower DC voltage. Might serve your purpose.
Think and move like an electron
03/28/2008 6:28 AM
Sorry, I gave you the wrong answer, didn't I?
you're after the powering of the pool pump. In that case I cannot help.
I guess using solar generated power as much as possible is a good idea. if it is only to drive the pool pump may not be worth the effort alone.
03/28/2008 8:17 AM
Ah ... maybe you just answered the wrong question
03/30/2008 5:42 PM
I have seen pumps that power fountains during daylight with one PV panel and one deep cell battery.
But for a filter pump, as the gentlmen above calculated, empowering needs are high. And the payback exists only in the satisfaction of not paying the utility for power, and, of course, the neat ability to power the pump by nature.
It is a questionable tradeoff though for the sake of less pollution because of the toxic nature of storage batteries - especially if they are not intensively managed.
In an aside though I agree, one can use thermosyphon (without power) for heating a pool by locating the flat plate collector lower than the pool.
Kind regards . . . cornelius
Register to Reply 16 comments
Anonymous Poster (1); corneliusvansant (1); DVader1000 (1); EV1guy2004 (1); Isti80 (2); m shroyer (1); madness (1); N5EBA (1); OpMan (1); PWSlack (1); user-deleted-1105 (5)
