Previous in Forum: transformer   Next in Forum: Differential Current Protection
10 comments
transistor
03/30/2008 6:37 AM
can a transistor be replaced with something better and faster in operation.
Re: transistor
03/30/2008 7:22 AM
Yes, but by what?..all this stuff about optical processing doesn't really address I/O and interfacing issues.
Re: transistor
03/30/2008 10:36 AM
Well, yes and no...
Re: transistor
04/05/2008 7:47 AM
Thanks for your reply am sorry that i never became specific as to where and why a transistor should be replaced with something better, I knew it will be challenging question to my fellow engineers but let me put it now a little bit clear ; in an amplifier.
Re: transistor
03/31/2008 8:50 AM
Better is pretty wide open.
"A sports car is better and faster transportation"
Unless of course you are trying to transport 9 yards of concrete!
Transistor is pretty open also.
Good Answers: 11
Re: transistor
03/31/2008 9:42 AM
Ok, now that all the smart alecs have weighed in...
You might try a FET of one variety or another. But as has been mentioned, this is going to depend on the application. Do you have a schematic of the present circuit that you can post?
Eric
Re: transistor
04/01/2008 7:43 AM
It may sound a little smart alec at times when the answers are as short and open as the question but it is import for people to learn to ask answerable questions. Maybe do enough research to get a basic understanding. I have watched many discussions here go on and on in 20 different directions because everybody is making assumptions about the original post.
Good Answers: 11
Re: transistor
04/01/2008 7:47 AM
True, a lot of the discussions would benefit by tighter descriptions. But three or four smart alec responses is a little over the top, isn't it? Face it, we're not that funny. We're engineers!
Eric
Re: transistor
03/31/2008 9:54 AM
Yes, with a better and faster transistor...
Aged man is not old man...
Re: transistor
04/01/2008 6:30 AM
How do you rate an "off topic" comment as on topic: all I've managed to do is reduce the "off topic" score. If seven people vote against it being "off topic" does it make the status of "good answer"?
Even ca1ic0cat's FET is after all a transistor (Field Effect Transistor).
Re: transistor
04/01/2008 5:26 AM
Would be helpful if you`d explain which operation you have in mind and what is "fast" for you.
You can use transistors par example not only as transistors but as tunneling devices - then tey do not operate as "normal" transistors but are - logically - still ones but are extremely fast for generating pulses.
But as long as we don`t know which application you really mean a qualified answer for your demands is nearly impossible.
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Register to Reply 10 comments
Anonymous Poster (3); ca1ic0cat (2); Mikerho (1); Qqberci (1); Randall (1); user-deleted-1105 (1); uweka (1)
You might be interested in: Transistors, Darlington Transistors
