Previous in Forum: Manufacture by reverse engineering special tools   Next in Forum: Pouland chain saw 2 years old used frequently
looking for manufacturer
03/31/2008 12:27 PM
I am trying to locate a company called "Air Konvoy" or " Air Konveyor" they used to build a machine called a Vackonveyor. Pressure/Vacumm pot for unloading bulk railcars.
Good Answers: 21
Re: looking for manufacturer
03/31/2008 3:15 PM
Just as Chris said...that is a tough one. Although the name sounds familiar I also could find nothing at all. It is quite possible this company has closed up or been bought up.
I would suggest making some phone calls to a few companies like Hapman, K-tron, Shick, etc.. Find one of their older engineers and they very well might know of this company. They also might be able to help you out with whatever you are needing.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
03/31/2008 11:46 PM
Try calling BN Burlington Northern Purchasing and they may be able to help or point you in the right direction....
04/01/2008 1:40 AM
Hello
I use to use one of these I think in the grain industry. We called it a vacuvator, hope this helps www.vacuvator.com
John 3:16
04/01/2008 1:00 PM
I found these references on "google" by typing in Air Konvey:
Barge having a pneumatic loading and unloading system - Patent 4525107
The "User's Manual" for
Air-Konvey's VACK II conveyor (Patent rights to the VACK II conveyor are owned by Premier Pneumatics, Inc.) is incorporated by ...
www.freepatentsonline.com/4525107.html - 64k - Cached - Similar pages
Apparatus for conveying particulate matter - Patent 4168864
AIR KONVEY CO. Primary Class:. 406/23. Other Classes:. 406/109. International Classes:. B65G53/22; B65G53/28; B65G53/04; B65G53/28. Field of Search: ...
www.freepatentsonline.com/4168864.html - 51k - Cached - Similar pages Hope this helps..
04/01/2008 1:04 PM
EVERY DRY BULK TANK TRUCK USES THESE...POWERED OFF THE TRUCK ENGINE EXHAUST WITH A TURBO MOTOR CREATING HIGH VELOCITY AIR...USE TO BULK HAUL ROOF ROCK...DELIVERED ROOF ROCK TO 3 STORIES HIGH WITH IT.
BULK CEMENT/GRAIN/ANY DRY BULK GRANULAR COMMODITY TRUCKS UNLOAD SAME WAY IF STORAGE IS ABOVE GROUND/SILO.
BEST ENERGY EFFICIENT?????NO WAY .........BUT CHEAP..QUICK...ALWAYS AT POINT OF NEED...USED VENTURI AT TRUCK GRAVITY BOTTOM TO MOBILIZE THE STUFF WITH A LITTLE TANK INGESTION/INJECTION TO MAINTAIN FLUIDITY IN SUPPLY TANK.
MR. GUY
If you are looking for a positive answer..it's YUP......
Anonymous Poster (1); AppleC (1); flashlight (1); Mr. Guy (1); Switchman (1)
