Previous in Forum: Earthed and unearthed cables   Next in Forum: electric motors
10 comments
ISOLATED PHASE BUSDUCT
04/01/2008 2:32 AM
WHAT IS THE DIFFERENCE BETWEEN SEGERATED AND NONSEGERATED BUS DUCT?
User-tagged by 1 user
Engineering Fields - Energy Engineering - New Member India - Member - Jack of all trades
Re: ISOLATED PHASE BUSDUCT
04/01/2008 4:30 AM
Hello guest,
A.
Non-segregated phase bus duct is available for voltages
ranging from 600 volts through 38kV, with ratings up to 8000
amps. The duct has all phase conductors in a common enclosure
with air space between phases. There are no metallic barriers
between phase conductors of adjacent points. Conductors
may be mounted on custom-molded, fiberglass-reinforced
polyester blocks or on post insulators. Enclosures that are totally
enclosed are preferred, but ventilated areas can be provided
in indoor applications. Typical applications include connections
between transformers and switchgear, tie connections
between motor control centres and large motors, and as the
main generator lead for small generators.
B.
Segregated phase bus duct is available for voltages ranging
from 600 volts through 38kV, with ratings up to 8000 amps.
Segregated phase bus has all phase conductors in a common
enclosure with metal barriers between adjacent phases.
Conductors may be mounted on molded, fiberglass-polyester
blocks or on post insulators. This design is primarily used as a
generator lead in power plants, but it is also used in heavy
industrial applications and as a switchgear tie in metal-enclosed
substations.
It takes considerable knowledge just to reaIise your own extent of ignorance.
04/02/2008 4:34 AM
ISOLATED PHASE busduct are generally used for the power plants ( generator to generator transformer connections ). In isolated phase busducts, each phase has separate enclosures ( non magnetic ) and thus the name isolated phase bus ducts.
In non-segregated and segregated busducts - all the phases are in a common enclosure without separation between phases and with separation between phases respectively. Used for connections in MV and LV distribution system.
07/10/2008 1:54 AM
Above reply is correct.
SP Rajput
11/26/2012 9:28 PM
sir, could you tell me about definition and aplication busduct?I don't know about aplication when we chose segregated and nonsegragated busduct?
thank you sir
04/01/2008 10:09 AM
SEGERATED:Phase conductors mounted on insulators in seperate enclosurs
NONSEGERATED :All Phase conductors in the same enclosure but seperated by insulated barriers or air
04/02/2008 12:43 AM
Mr J_kamal,
I afraid non segregated bus duct is used only upto LV voltage 415/480 etc level. Segregated from 3.3kV upto 33kV. Isolated 33kV and above. Please check.
BNDas
04/02/2008 1:17 AM
Mr. Das,
Both segregated and non-segregated bus duct configurations can be used for the voltage levels that I mentioned in my reply. The manufacturing practices differ from one country to another. Yup, in India we do prefer non-segregated bus duct for LV.
Kind regards,
05/09/2008 4:44 AM
you can e-mail to me, zhanglie@hotmail.com, i know the IPB/SPB/NSPB.
10/16/2008 3:14 PM
What is the benefit in using IPBD in large generators over either of the two other types of bus duct? It seems as though the magnetic field (even with non mag material such as stainless) would be so high (with generator currents in the 12k to 14k range or higher) that heating would be a major problem.
03/14/2024 4:24 AM
Easy. The presence of the segregation.
Anonymous Poster (3); biswanath.das (1); j_kamal (2); M_Okta (1); PWSlack (1); sj (1); zhanglie (1)
You might be interested in: Bus Plugs, Duct Heaters, Air Hose and Air Duct Hose
