hello all, i currently work on a company making products from stainless steel. however our superior is having doubts on the type of stainless steel being supplied to us. he suspects that the supplier might be giving us grade 202 instead of the grade 304 we were supposed to get. so he called on us to investigate, test the steel and identify what steel is being given to us. by the way we only have simple equipment like metallographic
microscope, rockwell tester, tension/compression testers in case they
might help. so i ask you guys about any method we can use to do this. i prefer the simpler ones but any suggestion you make will be highly appreciated. thanks!
