Previous in Forum: CNG Fuelling System   Next in Forum: ball point pen type mechanism ??
Compact valving for paste dispensing
04/01/2008 11:14 AM
Looking for ideas for valve bodies for a high viscosity water-based paste dispensing system. Need to have a small body (<5 cm dia ouside) that can control from 0 to 25 cc/sec with 80 psig max. operating pressure. I am looking at either proportional control or PWM. Any ideas? Please contact russell.moore@hp.com
Re: Compact valving for paste dispensing
04/02/2008 10:45 AM
Have you looked at Paintball Guns and how there valves work?
Bud Trinkel
04/02/2008 5:57 PM
Thanks for the idea, Bud. Are you referring to how they fill the paintballs? I have not looked into that. However, my fluid is higher viscosity, maybe similar to thick cake frosting (don't have specific rheology data). I haven't been able to locate much along this line in the food processing industry either (applications are typically too large).
Russ
04/03/2008 9:27 PM
Contact DOW or other adhesive manufacturers for the type of dispensing valves that they use.
Also "DYMAX" in the USA provide similar valves for their electronics encapsulant and potting materials.
Hobbies - Musician - New Member Engineering Fields - Manufacturing Engineering - New Member
04/03/2008 10:11 PM
Hi rusmoore
You might also try to contact Valco @
http://www.valcocincinnatiinc.com/coldglue.htm
They carry some very high viscosity hot and cold glue valves that might fit your need.
Hope this helps.
Courage is not the absence of fear, but the inner resolve to rise above it....or the inane lapse in judgement brought on by copious imbibitions....Egre Flagrus
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
04/04/2008 3:24 PM
Dirt is for vegetables. Pavement is for racing.
BudT (1); Just an Engineer (1); rusmoore (1); snygolfgs (1); unclefastguy (1)
