Previous in Forum: low impedence dry couplants for ultrasonic application   Next in Forum: Effect of Wind-induced fluctuations on atmospheric leg from press. trasnmitters
8 comments
0 - 5VAC output
04/01/2008 6:12 PM
I want to buy a small hand held unit with a 0-5VAC variable current output to use for input signal for RTU for testing and calibration purpose. If you have any advice to supplier or if it is easy let me know how to build one.
Thanks
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: 0 - 5VAC output
04/01/2008 7:26 PM
You could find something here
http://www.newark.com/
However, you may have to buy a unit with many features that youy don't need. It may be cheaper to make up an instrument on your own.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 53
Re: 0 - 5VAC output
04/01/2008 7:43 PM
0-5VAC variable current? I think that this is an April Fools prank.
Re: 0 - 5VAC output
04/01/2008 7:59 PM
Ace,
You forget where you are and what "guests" are capable of.
Still, you may be right.
Mike
Re: 0 - 5VAC output
04/02/2008 10:25 AM
Could some body explain to me that why there is no a 0-5VAC variable out put calibrator. I am wondering if the RTU is designed to take 0-5VAC input signal from the secondary CT line signal, how someone could test and calibrate from test bench before installing the RTU in the field.
Thanks
Re: 0 - 5VAC output
04/01/2008 7:57 PM
Hi Guest,
"hand held unit with a 0-5VAC variable current output"
Do you mean variable VOLTAGE output from 0-5V?
Mike
Good Answers: 73
Re: 0 - 5VAC output
04/01/2008 9:12 PM
Yup, I think i've been got.
Re: 0 - 5VAC output
04/02/2008 2:59 AM
Not for the first time ...
Good Answers: 73
Re: 0 - 5VAC output
04/02/2008 10:04 AM
Or last, I'm sure
Ace Boeringa (1); Anonymous Poster (2); Bricktop (3); Mikerho (2)
