Previous in Forum: ball point pen type mechanism ??   Next in Forum: GAS FLOW THROUGH PIPES
Pulley and belting
04/02/2008 12:30 AM
Hi guys
Is there any guideline in pulley and belting system. Example I want to transmit 20hp power and 80Nm tourque 1500 rpm from gearbox to alternator using the Vee belt. How many belt should I use? two groove, 3 groove pulley ? Guys..pls do help me
Pathfinder Tags: Belt and pulley
Good Answers: 137
Re: Pulley and belting
04/02/2008 5:04 AM
First of all, check your figures.
80Nm at 1500rpm only gives 16.85hp.
Cheers....Codey
04/02/2008 5:20 AM
yup 16.85 hp...
04/02/2008 11:17 PM
This information is available in any mechanical engineering hand book or in catalogs of best manufacturer.
Are you requesting others to calculate the things and give you straight answers?
Good Answers: 247
04/03/2008 12:12 AM
Gates has an application you can download called Gates DFPro. Given inputs such as power and speed and center to center distance, it will come up with an assortment of applicable pulley and belt combinations, from their line, which includes toothed, conventional, multi grooved, etc.
Register to Reply 4 comments
Anonymous Poster (1); Blink (1); Codemaster (1); haniff (1)
