Previous in Forum: Flow Measurment   Next in Forum: Transmitter Cable Entry
process control
04/02/2008 4:39 AM
hai all ,
I need answer for why we are following 3-15 PSI and 4-20 mA while dealing with process control Instruments?
Second question is what is the difference between a Sensor and a Transducer?
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: process control
04/02/2008 9:37 AM
From the little information you have provided, you are sending a 3-15psi signal to a transducer with a 4-20mA output. It should be set up electronically so that your psi setting produces a comparable digital readout.
But I really don't have enough information here.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 54
Re: process control
04/02/2008 9:49 AM
3-15 psi and 4-20 mA signals are called "live zero" signals. It offers two advantages:
  1. If the signal cable or pneumatic tubing is cut, the signal drops to 0 psi or 0 mA. This will help you in troubleshooting.
  2. If the signal cable or pneumatic tubing is cut, the system will surely go to the fail-safe mode. For example: if the 3-15 psi signal goes to a control valve. A 0 psi signal will force the valve to close (or open if it's air-to-close). Same principle applies for 4-20 mA instruments.
Of course, the "surely" only applies if the system fail-safe mode is properly designed.
As for the difference between "sensor" and "transducer", take your pick. For some people, they're the same thing. Others see them as different things. For me, it's not terribly important. At work, we say "sensor", never "transducer". Go figure.
