Previous in Forum: Spot Weld Pull Test Charts   Next in Forum: spring loaded bit or bit-older
Metric screws
04/02/2008 3:53 PM
I am trying to manufacture a Digital camera mount adaptor and I cannot find a source for an M1.8 .35 X 3 (Or 4) ,pan head ,Phillips drive ,stainless steel screw. If you know of such a source for small quantities please let me know . Thanks.Luis luis@sigmacumlaude.com
Good Answers: 230
Re: Metric screws
04/02/2008 3:56 PM
Hello Guest,
If you advise your location, it may be easier to assist you.
Kind Regards....
Good Answers: 15
Re: Metric screws
04/02/2008 4:09 PM
If you're in the USA you could try the McMaster.com web site
downhill slide to 112 (damn memor.)
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Metric screws
04/02/2008 6:26 PM
Every single Industrial supplier company will have one of these, as will all photo equipment suppliers.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Canada - Member - New Member
Good Answers: 11
Re: Metric screws
04/04/2008 6:12 AM
M1.6 and larger are available at many suppliers but strangely M1.8 is most often missing.
Make sure you this is the correct screw.
McMaster does not carry this screw with Phillips drive, only slotted.
Try your camera repair shop.
These may:
http://mdmetric.com/
http://www.microfastenings.com/Home.aspx
Good Answers: 266
Re: Metric screws
04/04/2008 1:32 PM
A M1.8 X .35 is not a first choice for a screw thread but it is a second. That will make it hard to located. The M1.6 X .35 or M2 X .4 is standard. In that you are manufacturing the mount I would change the screw thread if possible. If this is to attach the camera and that is the screw thread needed then check camera shops ones that do a lot of repair work for OEM screws. Fabricate the mount to utilize the OEM screws.
Bricktop (1); ddk (1); gigaconcept.com (1); ozzb (1); Sparkstation (1)
You might be interested in: Face Drivers, GPIB Converters, GPIB Switches
