Previous in Forum: Metric screws   Next in Forum: Steel Fence Posts
Engineering Fields - Mechanical Engineering - I am here to help!!
spring loaded bit or bit-older
04/03/2008 2:06 AM
I need some urgent help.
I need a spring loaded bit or bit bolder with standard 1/4" end (to engage with screw driver) & other end should be floating by 20mm with hex socket (a/f 7 mm) for driving a M4 screw.
Pls suggest some supplier.
Good Answers: 94
Re: spring loaded bit or bit-older
04/04/2008 4:49 AM
Do you mean the ¼" hex drive for a cordless driver? You can buy an adaptor from ¼" hex to ¼" square then add a deep 7mm socket, is that what you need?
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
04/06/2008 2:26 AM
Hi, pc!
It doesn't read like a complex request, but I'm not certain I follow. Perhaps you could diagram what you mean for easier understanding...
Mark
Register to Reply 2 comments
You might be interested in: Spring and Wire Forming Machines, Spring Pins
