Previous in Forum: spring loaded bit or bit-older   Next in Forum: Laser Cutting of Carbon Fiber
Steel Fence Posts
04/03/2008 8:54 AM
I am looking for information and resources on 'T' and 'Y' style fence post used on farms and ranches. The information should include inventor or first use, styles, types, pictures and just about anything you can think of.
Pathfinder Tags: farm fence post posts ranch steel t y
Good Answers: 143
Re: Steel Fence Posts
04/03/2008 9:05 AM
A homework project? Did you look at Wiki?
04/03/2008 9:24 AM
You might contact; http://www.ameristarfence.com/
They claim to be the largest manufacturer of fencing and they may be able point you in the correct direction.
On a side note; a "U" shaped post was used before the "T".
Good Answers: 243
04/03/2008 9:11 PM
You don't say where you are located, snodster, but if you can find an old copy of the making shaping and treating of steel, published originally by USSteel ( the older the better, anything pre 1984 will do) it should have a section on rolling of t shapes.
I can check my collection(in bookcases at work) in the morning.
milo
Good Answers: 243
04/04/2008 10:20 AM
I am sending to you two scans from making shaping of steel which describe rolling of fence posts./
In the days of bessemers, there was an abundance of bessemer rail steel. Reil slitting mills were developed to utilize this abundant feedstock.figure 29-11 shows a typical layout for such a mill
the second scan will show youthe rolling sequence of the fence post material it is the third sequence from the right in figure 29-21.
I'm sorry that I seem to lack the ability to attache .pdf's . They are just the default standard for 99% of the world, but somehow they are deemed contraband by the server here.
milo
04/04/2008 2:05 AM
Just going to Google and write "Steel Fence Posts", a lot of sites shall attack you offering their varieties of products: types, designs, sections, light- medium-heavy duty, and their prices.
- Fence Post Steel - Home & Garden - Compare Prices, Reviews and Buy ...
- steel fence posts Landscape Supplies - Home & Garden - BizRate ...
04/13/2008 10:06 PM
I have installed my fair share of t post in the past. Anything you want to know bout practical application?
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair...Douglas Adams
Good Answers: 25
04/26/2008 12:09 AM
The How Stuff is made show on TV showed a bit on this subject. The commentator stated that most of these type posts are Mfg.ed
from salvaged worn out rail road rail. These steel rails are soft enough to be heated, drawn and formed into extended lengths and are cut to size.
Toomuchfun
The only problem with common sense, is that not very many people have it, or know how or when to use it.
Register to Reply 7 comments
Abdel Halim Galala (1); Anonymous Poster (1); Milo (2); Toomuchfun (1); TVP45 (1); wgh71 (1)
