Previous in Forum: Laser Cutting of Carbon Fiber   Next in Forum: STAINLESS STEEL 316 - DEMAGNETISATION
method of removing an adhered film from a LCD
04/04/2008 11:04 AM
Can anyone give me ideas for removing a light adhesive film from the back of an LCD?
Good Answers: 66
Re: method of removing an adhered film from a LCD
04/04/2008 11:34 AM
A little bit of rubbing alcohol is generally pretty safe and effective. If the adhesive is stubborn, try some WD40 or other penetrating oil. Assuming, of course, the surface the film is attached to will tolerate either alcohol or oil for a short time.
Aequam memento rebus in arduis servare mentem.
04/04/2008 12:01 PM
If that doesn't work, try using zippo lighter fluid!
04/05/2008 2:40 PM
Hey!!! don't forget LCDs work only by having a polarizing filter before and after the LCD.
Using any form of solvent will destroy the polarized film and make the LCD useless!!!
OP, don't try removing any film on the LCD at all, and if you do make sure it is supposed to be removed and then use only water and very gentle rubbing etc...
I hope he's not cleaning his new flat screen TV!!!
John.
04/05/2008 4:01 PM
My next idea was a metal scouring pad so lucky you got there first!
CSM Engineer (1); Electroman (1); Mr. Truman Brain (2)
