I have been thinking that if an electric induction motor with integrated flywheel for torque and gearbox that fits directly into each wheel of a motor car were used(they could be part of the wheel) instead of a single motor and transaxle system, we could use the motors more efficiently. Meaning, they would use less power(individually) and give better acceleration initially(from stop to cruise) without the energy losses from the transmission. When cruising, some or all but one could be switched off to save battery power. Then during coasting or breaking they could all be used to regenerate charge to the battery. Another aid to acceleration is to use torsion springs that would engage when the brakes are applied to stop and the energy is stored and released when the car is moving off again. A one-way clutch system could be used to allow for reversing. I would like to see some of these Ideas come to light as there are always popping into my head.
Your comments or criticisms are welcommed. Thanks
