We have a conveyor that feeds several downstream conveyors which is made possible through a shuttle system. A shuttle frame is moved by a rack and pinion arrangement. The pinion is driven through by a 135 kw motor. The motor speed is reduced through a reducer. Recently we have been encountering catastrophic failures on the flexible coupling on the high speed side. I have done calculations to confirm the current coupling's torque ratings and it is within acceptable range, we have also done alignment checks and it is not an issue as well. Would anyone out there think of anything esle that I should check out for.
