I forgot my password.
Don't have an account?
CAN SOMEONE HELP ME FIND A SINGLE PHASE 1hp MOTOR OPERATING AT 230V, 50Hz and a speed of 1450rpm.
If you are in the US, try McMasterCarr.com.
It sounds as if you need to replace an existing motor. It should be easy to replace a 1 HP with a 750 - 1000 watt motor.
Do the dimensions differ or is the exact speed a problem?
IT IS DIFFICULT TO GET THE MOTOR AS REQUESTED BY YOU.
SIGLE PHASE MOTORS ARE EITHER
1. SPLIT PHASE TYPE IE CAPACITOR START MOTORS .
2.UNIVERSAL MOTORS .
NOT THE GENERAL SQUIREL CAGE INDUCTION MOTOR WHERE 1450 RPM IS POSSIBLE IF THE SUPPLY FREQ IS 50HZ AND MOTOR HAS 4 POLE.
How many u want.These are available at all dealer outlets.The rpm in any ac motor depends on load and if u want a higher rpm select next higher hp motor
