Previous in Forum: logging in   Next in Forum: Useful Noise? or just Statistics?
16 comments
Rust Detection
04/11/2008 7:19 AM
What are methods for chemically, or otherwise, determining rust. In this case iron oxide, is present on a painted surface. I have an inquiry from a field service Rep who has sent pictures of a painted aluminum surface with rust spots (2-3 mm dots) red orange in color. Presumptions are these spots are sourced from welding or grinding steel close by the surface in question. That is , depositing the dust on this painted surface and subsequent oxidation. easy enough to surmise that but difficult to prove over the phone. Does any one know of a no destructive test to verify the oxidation is in fact ferrous metal oxide say as opposed to something that looks like metal oxide.
If you die in the south - going up or down - you have to go through Atlanta - and there will be a layover.
Re: Rust detection
04/11/2008 7:45 AM
Hmmmm is it possible to wipe these spots off the painted surface and show that the paint is intact and not rusty?
Does that prove that the corrosion is after it is installed and is due to contamination?
Is the customer complaining that the rust spots were because of your fault... i.e. supplying contaminated paint??
I'm not sure I'm following this at all... John.
Re: Rust detection
04/11/2008 9:57 AM
Thanks for the fast responce. - Regarding wiping the spots off - I can presume the field personel have tried that - but will ask. I would agree that if you could wipe the spots off that the contaminates were post shipping. In the event they do not wipe off I was looking for some sort of field test that would verify that is was infact an iron oxide as opposed to some other contaminate exhibiting the same orange/red tinge.
It is possible the customer is hinting the defect came from the supplier. I have only recieved the first report of the problem and have not seen this defect reported in the past. We only use aluminum and SS metals in our product along with 2 mils of Powder coat paint - this failure mode has never surfaced. Ive checked the process eliminating any probable/possible contamination in the assembly stages.
I'm thinking there is a quick field test to verify the partical in the contaminate (other then magnets) is a ferrous metal. In this case there is no visable solids that could be picked off with a magnet - only the residue indicating that it may have been ferrous metal. Give our lack of experience in dealing with this failure mode It seemed faster to ask those who experienced similar defects..... Tom
Re: Rust Detection
04/11/2008 9:10 AM
Just run a magnet over the spot. Look at the magnet. Does the magnet show these "dots". If it does, the indication is that someone nearby was grinding or welding ferrous metal. Clean away these spots and touch up the aluminum painted surface if was damaged. Aluminum will not be attracted to the magnet.
Re: Rust Detection
04/11/2008 9:58 AM
Ferrus oxide will not be attracted to a magnet either, I think?
John.
Good Answers: 18
Re: Rust Detection
04/12/2008 1:34 PM
Correct.
Re: Rust Detection
04/11/2008 10:01 AM
Thanks for the response - Ther are no solids I can see in the picture that could be pick off by a magnet.
Re: Rust Detection
04/11/2008 10:11 AM
Perhaps someone has already wiped away the grinding dust, but not before the paint was damaged. If the dust is gone, then the next step is to rub the spot and look for pitting. Galvanic corrosion is a possiblility as well.
Re: Rust Detection
04/11/2008 10:17 AM
Good idea Thanks
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: Rust Detection
04/11/2008 9:19 PM
I'm a bit rusty (excuse the pun) on chemistry, but I think you could lightly spray the surface with something that will react with the oxygen in the rust. You would want to use something that would produce a visible reaction, so that a field hand could use it.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Re: Rust Detection
04/14/2008 8:00 AM
Correct - I believe I have a response that has provided the answer --Thanks
Australia - Member - New Member Popular Science - Cosmology - New Member Hobbies - Fishing - New Member
Re: Rust Detection
04/11/2008 10:56 PM
Mate,
Try using a rust converter. It is basically concentrated phosphoric acid. Turns iron oxide into iron phosphate. you will notice virtually straight away. Cheap.
Try Septone Rust Converter. Cheap about $10-20 a 250ml bottle, from your local car parts store
Used it on my EJ Holden Station Wagon. Just be careful about using it as it may fade you duco if your not careful about spills, or drops.
If you don't laugh, you cry.
Re: Rust Detection
04/14/2008 8:09 AM
Thanks - I believe this would correct the problem and provide evidence the stain is infact iron oxide. I suspcet we could swab some on the surface to performt he test.
Thanks for your information
Good Answers: 19
Re: Rust Detection
04/12/2008 1:44 AM
The Potassium Ferricyanide test is old but reliable. There is some information here.
http://www.waterjetting.org/test.htm
The Potassium Ferricyanide solution should turn the brown spots blue very quickly if in fact they are rust.
Re: Rust Detection
04/14/2008 8:13 AM
Thanks for the info - I checked out he site - very interesting approach. will pass this on to our field rep.
Re: Rust Detection
04/12/2008 1:39 PM
what is the possibility of using a rust remover such as oxalic acid?
Re: Rust Detection
04/14/2008 8:16 AM
I will look into this - thanks
Register to Reply 16 comments
3Doug (1); agua_doc (1); Anonymous Poster (1); bubbapebi (1); Electroman (2); geomech (1); tom@windoor (7); user-deleted-9 (2)
