Previous in Forum: Why is There a Difference in Tides Place to Place?   Next in Forum: Tricky Problem
14 comments
finding the height
04/12/2008 10:27 PM
two Tv sets, sitting beside eachother on a shelf in an appliance store,have the same screen height.one has a conventional screen,which is 5in. wider than its height the other has a wider high-definition screen which is 1.8 times as wide as its height. the diagonal measure of the wider screen is 14in. more than the diagonal measure of the smaller. what is the height of the screens,to the nearest 0.1in.??
Good Answers: 143
Re: finding the height
04/13/2008 6:04 AM
Is this a riddle? If so, the answer is 45 barleycorns.
Good Answers: 15
04/13/2008 8:07 AM
no, you are wrong, the answer (and you're not going to like it) is 42.
If you don't have time to do it right the first time, when are you going to have time to do it over?
Good Answers: 143
04/13/2008 8:22 AM
42 what? You better not be using Imperial Barleycorns! Is there a trick to subtracting the edge of the screen that I didn't consider?
Good Answers: 101
04/13/2008 11:00 PM
42 is the ultimate answer to life, the universe and everything.
Good Answers: 143
04/14/2008 5:21 AM
Drat. I've been assuming it was the White Album. No wonder my life is a shambles!
Good Answers: 230
04/13/2008 7:15 AM
Hello rams20
Thankfully we converted to metric measure, over 30 years ago.
Kind Regards....
Good Answers: 74
04/13/2008 6:51 PM
Sounds like a homework question. It is not much of a riddle as the answer may be readily obtained by solving a quadratic equation. High school stuff!
Bruce
04/14/2008 9:49 AM
Numbers don't matter. It's more of a personal preference issue.
Have you noticed that a circle on the smaller screen is a circle and on the wider screen it is an oval? I wonder if the manufacturers realize that...or is it a conspiracy to distort our concept of life.
Nothing exceeds like excess.
04/14/2008 1:28 PM
John Barleycorn is dead...........and the oval is stretched by that feature that makes people's faces fat, choose a different zoom; but you knew that all along you crafty dog.
Eschew obfuscation.
Good Answers: 143
04/14/2008 8:33 PM
rams20,
You've been demoted to rams19. You made a typo somewhere in this riddle.
05/13/2008 1:11 PM
The height of the sets is 27.4". The problem can not be solved by quadratic equation and a little more difficult than high school math.
Good Answers: 74
05/13/2008 2:31 PM
Your answer is correct. Your statement is wrong. The problem can be solved by quadratic equation. Consider:
d12= 2h2 + 10h +25
d22 = h2 + (1.8h)2 = 4.24 h2
d1 = d2 - 14, or, squaring both sides,
d12 = d22 - 28 d2 + 196
2h2 + 10h + 25 = 4.24h2 - 57.6h + 196
-171 = 2.24h2 - 67.66h which is a quadratic equation with solution h = 27.4
Please grovel a little for putting me to all this trouble.
Bruce
Good Answers: 143
05/13/2008 7:11 PM
I'm not trying to get outa groveling, but I still think the question is flawed. Think aspect ratio.
Good Answers: 74
05/13/2008 7:53 PM
I don't see the flaw in stating the problem. I'm thinking aspect ratio, but it doesn't seem to help. By the way, I missed out a couple of superscripts in the equation reading:
It should have read:
Incidentally, a quadratic equation must have two roots. The second root is:
h = 2.78"
The first TV set would be 2.78 x 7.78 with a diagonal of 8.267". The second would be 2.78 x 5.012 with a diagonal of 5.233". The two diagonals would be 8.267" and 5.233" which differ by 14" when a negative value is taken for d1 in the equation:
d12 = (d2 - 14)2.
It is hard to visualize a negative diagonal, so I opted for h = 27.4 as the correct answer.
Okay TP45...you don't have to grovel...provided I can quit thinking aspect ratio.
Bruce
Register to Reply 14 comments
Anonymous Poster (1); ba/ael (3); charlie_r (1); DVader1000 (1); Jaguar (1); Kyoto (1); Sparkstation (1); TVP45 (5)
