Previous in Forum: Soda Pop Machine needs TLC   Next in Forum: design of chilled water pipe system for multistorey building
Steam Turbine power station
04/14/2008 4:55 AM
what is the function of the Condenser in the Steam Turbine ?
Pathfinder Tags: STG
Re: Steam Turbine power station
04/15/2008 5:12 AM
To reduce the pressure in the line downstream of the turbine, and therefore to provide a greater pressure difference across the turbine. The result is more shaft work from the same fluid circuit and an increase in thermodynamic efficiency compared to not having one.
Please refer to a textbook on Thermodynamics and study 'thermodynamic cycles'.
