Previous in Forum: Building My Own Home Generator   Next in Forum: Potentiometric Joysticks
Measuring Residual Chlorine Salts on Metal Surface
07/05/2006 8:18 AM
I need advice for measuring residual chlorine salts on stainless steel tube surface per square feet area on inside and out side.
Can we use EDS Energy dispersive spectroscopy / XRF Emmission Spectroscopy / FT IR / SEM Scanning Electron Microscopy or what else and how?
What are the instruments available and where?
KKjain
Measuring Chlorine salt deposits on tube.
07/06/2006 2:15 PM
Is this to be a none destructive test or is it a once only test??
What amount of salt build up would you be expecting to measure
And
What accuracy would you be looking for?
thanks - John@march-designs.co.uk
Good Answers: 32
Re: Measuring Chlorine salt deposits on tube.
09/25/2006 1:14 AM
I agree with John that you need to specify the amount. I believe it is in ppm level or ng per sq. cm. hence use distilled water to disolve the salt and estimate it chemically. If salt is not water soluble, then use mild acid HNO3.
Netherlands - Member - New Member
Re: Measuring Residual Chlorine Salts on Metal Surface
09/04/2009 3:09 AM
I agree with Shyam a standard way of measuring the soluble salts on steel is defined by ISO 8502-6 in the bresle method, check this out http://www.bresle-method.com/en/index.html
Register to Reply 3 comments
Anonymous Poster (1); Raoul Kleinveld (1); Shyam (1)
