I have been looking at the Black and Decker, as well as the Neuton cordless electric walk-behind lawn mowers. I see that the cutting width is typically smaller than gas powered mowers (14-18" vs. 21-22"), but that may not be a big deal if the battery life can mow 1/3 acre or so on one charge. The purchase prices are comparable with gas powered mowers (at least with the B&D). They are much quieter under operation, and have less maintenance needs (fuel filter replacement, oil changes, etc.). The battery would likely need to be replaced every few years for likely $100 - $200 USD. I do not know that the amount of gasoline used in a gas mower adds up to the battery costs and charging costs of the electrics. A decent sized yard can be cut on a quart of gasoline or so. I am not sure about the plastic construction of the electric mowers (I know that a steel frame mower can take a rock being shot out of the blades no problem, not sure on the pastic).
I am just trying to approach this from all angles before I purchase anything. I don't have any experience with the cordless electric mowers, but lots with the gasoline variety. The electrics are attractive because of the low noise factor, low maintenance, and supposed long life span. They are unattractive because of the smaller cutting width, battery costs, and light-weight (but ~strong) construction.
Does anyone have experience with the electric mowers or opinions?
Debate!
