Previous in Forum: Why Is My Pump Stuck?   Next in Forum: spin forming
14 comments
How can i be using ASME codes on the internet to do my design?
04/16/2008 11:50 AM
I am a mechanical engineer by profession(Pupil engineer) and i need ASME code to be doing my design but i dont know how i can be tracking down these code on the internet.
Good Answers: 266
Re: How can i be using ASME codes on the internet to do my design?
04/16/2008 12:34 PM
04/17/2008 12:11 AM
To design a pressure vessel in accordance with ASME code, Section VIII, Division 1, ASME Boiler & Pressure Vessel Code VIII/Div.1 (ASME
To select the standard flanges: ASME B16.5 Flanges
Also, see : Thin-Walled Pressure Vessels & Topic 6.5 - Pressure Vessels
There is a lot if you need and interest.
04/17/2008 3:11 AM
Very interesting site for types of ASME standard flanges and their dimensions: ASME Flanges, in PDF formats, used in ASME pressure vessels and piping.
04/17/2008 10:05 AM
Nice information package- Thanks!
04/17/2008 5:50 AM
Thank you for your information .But i still need more information on how i can go about to design for a small retail outlet LPG plant.Thanks alot
04/17/2008 6:32 AM
If that LPG retail outlet composed from a pipe and flange, the mechanical design of both in accordance to ASME shall be as following:
1. For pipe design , please see CR4 thread High Pressure Steam Pipe just as example.
Note. This example is solved based on ASME B31.1 Power Piping, but for LPG piping you can use the ASME B31.3 Process Piping, or ASME B31.4 Hydrocarbon pipeline.
2. For selection of flange rating, please see the site ASME B16.5 Flanges
04/17/2008 12:04 PM
Nice!
Thanks again!
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
04/17/2008 7:13 AM
You Probably can't find it on the internet, it is protected by copywrite. ASME sells the code books. Believe me thay are expensive. I suggest that you go to a technical library that may have the books or possibly a CD Rom with the code on it.
04/17/2008 9:14 AM
Adefikayo:
As pointed out, the ASME Boiler and pressure Vessel Code parts are expensive, and not available (legally) without cost as they are all copyrighted documents.
Additionally, I think that the assumption was that the application was a pressure vessel, but the pressure vessel code itself, ASME Section VIII, has threee seperate Divisions, each independent of the others, and sold seperately as well.
If it is a Pwer Boiler that is the basis of the design (ASME Section I), then it would drag in by reference ASME B31.1 (one part of the piping codes).
In any case the material standards (ASME Section II - Parts A, B, C, D - all seperate volumes) would be a necessary refrence source, at least part D, which is where the stress values permitted for design are located.
Then there are the welding and brazing qualification requirements (ASME Section IX), and the Non Desrtructive Examination requirements (ASME Section V).
In all, I would say that unless this is being approached as an exercise, the project should be approached with cation, as there are a large number of potential pitfalls.
"We have met the enemy, and he am us" - Pogo
Hobbies - DIY Welding - pipewelder
04/17/2008 11:00 AM
I purchase my ASME books every 3 years and I get the new addendum every year. Although I still get my books in hard copy you can get them in electronic from the ASME site. I gave nearly $7,000.00 for my last set with new binders. You can get allot of info from the many commercial sites that sell different ASME rated products but for designing purposes I think you will have to pay for it. You may only need Sec. II, Sec. VIII, Sec. IX and B31.3 for your design though and not the 15 different books that I buy for my work.
pipewelder
pipewelder
04/17/2008 5:41 PM
EXAMPLE for Design Calculations of Pressure Vessel (Shell)
Page : 8 of 110
According to ASME Code, Section VIII, Division 1, 2004 Edition, Addenda 2006Sheet : 1 of 4
Designed by : Eng. Abdel Halim Galala, Design General ManagerREV. : 1
Project : Design & Procurement of ASME Pressure VesselDate : 6.10.2006
Job Name : Demineralization PlantJob No. : 7402-33
Serial No. : 7402-33-U--2003 Dwg. No. : 7402-33-1, Rev. 1Client : APRC
Vessel : Reactor Item No. : 1-D-1 Capacity : 21 M3Type : Horizontal
H. Cylindrical Shell Thickness Under Internal Pressure [UG-27(c)]
Shell material, Killed Carbon SteelASME SA515 Grade 60
Shell material Specifications
[Table 1A, Suppart 1, ASME Sec. II, Part D]
P-No.1
Group No.2
External Pressure Chart No.CS-2
Vessel ID102.7559INCH2610MM
Shell ID102.7559INCH2610MM
Shell Inside Radius,
R
51.37795
INCH
1305MM
Shell length from Tangent-to-Tangent (T/T), L82.677INCH2100MM
Max. Design Temperature572
oF
300
oC
Min. Design Metal Temperature, MDMT32
oF
0
oC
Max. Operating Temperature572
oF
300
oC
Operating Pressure312.5PSIG22KG/CM
2G
Max. Internal Design Pressure454.545PSIG32KG/CM
2G
External Design Pressure (Full Vacuum)15PSIG1.056KG/CM
2G
Shell Inside Diameter,D102.756INCH2610MM
Shell Inside Radius,R51.378INCH1305MM
Static Head = Vessel Diameter2.61M
Static Head Pressure (water head x sp. gr. 1.0)3.707PSIG0.261KG/CM
2G
Internal Design Pressure,
P (MAWP)
458.253
PSIG
32.261KG/CM
2G
Max. Allowable Stress @ Design Temp.(300
oC),S
16596
PSIG
1168.358KG/CM
2G
Max. Allowable Stress @ Test Temp.(100
oC), St
17100PSIG1203.84KG/CM
2G
[Table 1A, SubPart 1, ASME Sec. II, Part D]
Hydrostatic Test Pressure, P
h = 1.3 x MAWP x (St/S) [UG-99(b)]
613.821PSIG43.213KG/CM
2G
Corrosion Allowance,
C [UG-25]
0.079
INCH
2MM
Joint Efficiency,
E [TABLE UW-12]
1
[Full Radiography],
[Table UCS-57]
Value of 0.385 SE
[UG-27(c)(1)]
161.273PSIG11.35362KG/CM
2G
Since P does not exceed 0.385 SE, Use Thin Wall Equation:
[1] Min. Wall Thickness for Longitudinal Joints,
t1 = PR / (SE - 0.6P) [UG-27(c)(1)]
1.443
INCH
36.652MM
Value of 1.25 SE
[UG-27(c)(1)]
523.6138PSIG36.86241KG/CM
2G
Since P does not exceed 1.25 SE, Use Thin Wall Equation:
[2] Min. Wall Thickness for Circumferential Joints,
t2 = PR / (2SE + 0.4P) [UG-27(c)(2)]
0.705
INCH
17.907MM
The min. wall thickness shall be the greater of t1 or t21.443INCH36.652MM
By Adding Corrosion Allowance to Wall Tickness, t1.443INCH36.652MM
Use Thickness of Construction,t (Adopted thickness)
1.457
INCH
37MM
Corroded Thickness = Adopted thk. - corrosion allowance1.378INCH35MM
04/17/2008 6:02 PM
Sorry, there is a correction: Material ASME SA515 Grade 60 is Group No. 1 (not 2).
03/10/2009 9:33 AM
Hi... iam working on pressure vessel design and analysis..
i wanted to know allowable stress of SA420M GR WPL6 material with compliance with UG-23
Thanks
RAJA
02/28/2013 2:17 AM
Useful info.
Register to Reply 14 comments
Abdel Halim Galala (5); adefikayo (1); Anonymous Poster (1); Dan W (1); flynnstar (2); Morgan 23 (1); ozzb (1); pipewelder (1); ssraja (1)
You might be interested in: Bar Code Scanners, Bar Code Cards, Bar Code Software
