Sounds like you're making push rods. Considering the alloy, I think this is a forging job rather than spinning. How long is the tube and is it straight with the other end open? Is the closure to be air tight? If so, what is the test pressure requirement? How many pieces does the job involve?
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Spin form can be used to seal like a forge or weld. Same process as spin welding. Friction to heat then pressure to form/close. Is this what you are referring to?
If simply closing the tube you could use different methods such as ram forming, progressive forming, etc. Depends on the final shape you are looking for.
There are standard end forming machines and tooling available.
Need a little more information. Length of tube, tolerance required, finished form, etc.
-why bother doing it wrong when it will be anyway.......
It needs to be airtight. It will be boron coated and used as a thermocouple seath in molten aluminum to control the temperature of a small open crucible R and D bath.
We already made some that I hammered flat. I could not crimp them shut in the vise because they are too thick. But we would like them to be more "professional" looking.
So I would like to round the end shut like a test tube.
We have a drill press..Can I use a V block and spin it into the V block and form it?
Might work if you heat the end you wish to form to it's plastic state. You might have to weld the end if you wind up with a small hole. If you try it, I'd like to know the results. I love ingenuity.
