Previous in Forum: forklift maintenance   Next in Forum: Will it be too late to change transmission fluid if a car is already slow?
Good Answers: 97
Battery Type used in Sub-Zero temperatures for transportation Vehicles
04/16/2008 11:07 PM
How to ensure survivability in sub zero temps using electric powered automobile?
Pathfinder Tags: electric vehicle
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: Battery Type used in Sub-Zero temperatures for transportation Vehicles
04/17/2008 2:10 AM
I believe gel-cell batteries were created for this purpose. Plus they are safer to deal with in a spill. Otherwise, I'd say the amp-hour rating is the most important parameter to look at. Even if the electrolyte won't freeze, it does you no good if the battery runs down when you're miles away from your warm charging station.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
04/17/2008 8:04 AM
Part of it is to select the correct batteries for the expected ambient temperatures. The rest comes down to mechanical design for the expected conditions and appropriate thermal insulation.
Register to Reply 2 comments
