Previous in Forum: i have a question about airconditioning systems   Next in Forum: offset rolling
Mr.
04/19/2008 11:49 AM
what is double dwell intermittant rotary motion????????
Re: Mr.
04/19/2008 1:32 PM
That could apply to an Indexing Table that has a set number of fixed positions and these positions are controlled by a cam that is turned by a cotinuous running motor. To get the Table to dwell longer at a station they use Double Dwell.??????
http://www.allenair.com/pdf/RotaryIndexTables.pdf
Bud Trinkel
Good Answers: 97
Re: Mr.
04/19/2008 1:52 PM
Dwell - is a pause in motion - for example when you reach a depth with a drill you wait for a short period of time before retracting or continue with the next plunge.
double dwell - may then be a longer dwell or two distinct dwells at different depths.
Rotary motion is like a shaft or around a pivot.
intermittent - is like at random otherwise it would be regular.
An electric or electronic fault could be intermittent.
the rotation of a shaft could also be intermittent. and dwell before it changes direction.
Maybe you should state the type of machine you are enquiring about.
Register to Reply 2 comments
