Previous in Forum: Metal Detectable Plastics   Next in Forum: Calculation-Volume of Droplet
Strip turbine blades coating
04/23/2008 4:36 PM
Hi, I need process or liquid solution (Acid) for strip coating for industrial turbines blades.
Thank
South Africa - Member - New Member
Re: Strip turbine blades coating
04/24/2008 2:17 AM
Hi guest
your turbine blades are coated with what?
04/24/2008 2:21 PM
with Al-Pt pack process, and some cases only Al difusion pack
04/24/2008 10:46 AM
Try sandblasting.
Pineapple
Good Answers: 109
04/25/2008 5:04 AM
Hi,
so if your coating is mostly Al203 = alumina then this is soluble in HNO3 around 20% concentration and warm if not acting with sufficient velocity.
But this will attack also your base-metal, so you should add the nitrates of your base-metal to slow down this dissolution. May be this works, may be not.
Else you can try to dissolve the alumina in molten Na2CO3 (Soda), this will selectively dissolve only the oxides.
Please try and let us know what are the results.
RHABE
Anonymous Poster (1); Casper (1); Pineapple (1); RHABE (1)
You might be interested in: Saw Blades, Fan Blades and Propellers, Metal Strip
