Previous in Forum: How to select Capacitor Bank for Electrical Panel.   Next in Forum: Ligting illumination
Quasi-Diodes
04/28/2008 3:57 AM
Are there commercially available FETs that operate as a quasi-diode? Where can I get specifications?
Re: Quasi-Diodes
04/28/2008 7:22 AM
As a fet operates on the field effect caused by the voltage on the gate influencing the conductivity of the bulk N or P type drain to source silicon.
No... (at least not that I'm aware of)
You could use a bipolar transistor as a diode?
John.
Re: Quasi-Diodes
04/28/2008 7:55 AM
I am not familiar with your exact need but JFETs make very good low leakage diodes. The gate tro drain or gate to source junction is a silicon diode. They have slightly higher voltage drops but very low leakage.
Re: Quasi-Diodes
04/28/2008 9:09 AM
Ooops you are quite right guest.... my mistake I was thinking of mosfets...
John.
You might be interested in: RF Diodes, High Voltage Diodes, GUNN and IMPATT Diodes
