Previous in Forum: Old Dishwasher: Poor Performance   Next in Forum: Steel Truss Water Tower: Stability Questions
Downloading LINUX Apps on a Windows Box
05/02/2008 6:34 AM
I have two PCs, but only one is connected to the Internet. One runs on Windows and the other on LINUX. My Windows box is connected to the Internet, but not my LINUX box. So, is it possible to download LINUX programs on my Windows box, copy them to a CD, and install them on the LINUX box.
Good Answers: 140
Re: computers
05/02/2008 8:06 AM
Get your self a small cheap Ethernet router, less then $100.00, and plug both machines into it. That way you can share your connection. This won't work if you use a dial-up connection from the PC. If that is the case, there are other ways to do it. Are you on dial-up?
Re: computers
05/03/2008 8:25 AM
I am using ADSL,a normal land line connection,The "Ethernet router"will cost me more in Namibia,computer parts or computer extras are expensive.If you get it for $100.00 then I will most probably get it for N$900.00!!!
Re: Downloading LINUX Apps on a Windows Box
05/03/2008 2:08 AM
Yes, for sure. Any LINUX application can be downloaded in a Windows computer to be transfered via USB flashdrive or even a CD/DVD media into a LINUX computer.
In fact, you can even download LINUX OS like Ubuntu and Fedora Core to Windows computer and create a CD/DVD copy for your installation of the OS into another computer.
"The more I learn, the more I know the less I've learnt"
05/03/2008 8:37 AM
THANX FOR THE HELP!!!I will go and have a look and see if I get the Apps to work on my LINUX box.
Good Answers: 213
05/03/2008 9:41 AM
I have been doing exactly this for a couple of months. I run Ubuntu 7.10, and download both "tarball" applications and *.deb applications with a Windows machine, burn a CD, then load the applications from the CD. There are problems, however, associated with very complicated "depends" replationships- a package might not install because you don't have some other package installed, which won't install because you don't have some other package installed, and on and on. Eventually, most of the time, you can get everything sorted out, but occassionally one runs in to "circular" depends, in which case two applications demand that each be installed first. There is a command work-around for this. I have also run in to cases where the package manager complains that a package required for a new application is not loaded on the machine, yet turns around and tells me it is installed on the machine. Loading applications is one of the serious limitations of Ubuntu- I do not know if this is a problem with other Linux flavors...
cwarner7_11 (1); North of 60 (1); Phantomxxx (2); willyap06 (1)
