Previous in Forum: DC Motors and Parts for an Electric Suburban Trike   Next in Forum: Downloading LINUX Apps on a Windows Box
72 comments
Old Dishwasher: Poor Performance
05/02/2008 3:07 AM
Our old dishwasher is leaving a dirty residue where it isn't rinsing off the crud*.
I've done all the cleaning of filters and unblocking nozzles, checking the arms are free.Plenty of salt and rinse aid...
My guess is the pump isn't providing enough oomph* any more.
Is it worth stripping the whole thing down ...and maybe replacing the pump?
It's a Bosch...good reputation crap design (although it is quiet)...it must be about 8yrs old...but I don't like throwing stuff out.
(It was our first dishwasher...I'll know what to look for when I buy a new one.)
*... Technical terms
Re: Old Dishwasher Poor Performance
05/02/2008 3:29 AM
"Our old dishwasher is leaving a dirty residue where it isn't rinsing off the crud*."
Make a bit of a fuss. You do it (once), by her some chocs, make her a cuppa, let her put her feet up .
05/02/2008 3:32 AM
.. yeh..flowers usually work. .
She always insists on loading the damn thing (crams too much in...but hey whadda I I know I'm just an Ejinear?) Is that just Mrs Cat or is a Woman thing???
05/02/2008 11:59 AM
Woman thing.... Ms S does it as do all three S daughters...
05/02/2008 5:02 AM
ROLFHARRIS!!! Check the heater element aswell!
05/02/2008 6:06 AM
Good 'un...I'll check it's hot when it finishes next time.
05/02/2008 3:31 AM
I tell Mrs K to have a break now and then. After a cup of tea she can do the job much better, even if her overall time in the kitchen is longer. Sometimes a box of chocolates helps, as do unexpected flowers.
05/02/2008 3:56 AM
Blimey, JohnDG got in before me with some kind of time warp thingy.... It's a bit like The Matrix. There's another thread at present where somebody has a whiffy washing machine (and Ice-cream maker).
05/02/2008 4:48 AM
I s'pose in Hades you just use paper plates and they burn (eternally) afterwards?
05/02/2008 6:11 AM
We send an Engineer in.......
05/02/2008 7:07 AM
...Yeh...I just done that...the bloody thing isn't designed to be taken to bits...
The ass'y with the pump goes in from the bottom...but everything is built on top of a big plastic base molding....so I'd have to remove the door, sides, top, back and take the main enclosure off it....
Maybe using it for target practice is the best idea... Now would a bodkin point penetrate the front door...?
05/02/2008 11:58 AM
Well of course it's designed that way, they don't want you fixing the thing yourself. What next ? Small plastic lugs that break and can't be replaced ? Microwave turnatable plates that are different on each machine ? All these things happen for a reason, in the case of your dishwasher it's to test your ingenuity in taking it apart. The real challenge is explaining to Mrs Cat why it's not economically viable to reassemble the thing. Vital componants that would take weeks importing from Kamchatka etc. She'll love you even more for your earnest endevours, just don't let her find any of the screws that got lost.
Engineering Fields - Marine Engineering - New Member United Kingdom - Member - New Member Engineering Fields - Mechanical Engineering - New Member
05/02/2008 5:49 AM
I took the easy option and bought our second one in November last. Saved £'s of ear bashing and phoning and stripping down etc,. Mine was the programme just died.
Reset, Reset
05/02/2008 6:04 AM
I s'pose I could use it to test the penetration power of my Longbow.
Just in case we get invaded by manic Dishwashers.
Re: Old Dishwasher: Poor Performance
05/02/2008 2:00 PM
Had the same problem with my 9yr old one recently.
At your local supermarket look for dishwasher cleaner, it's concentrated citric acid.
It took four bottles / four wash cycles to clear mine but now it's good as new.
No disassembly required.
Charlie don't surf.
Good Answers: 266
05/02/2008 3:26 PM
Heres some help Del some where it said gunk can build up in the pump impellers reducing the flow. May just need to be cleaned out.
http://www.acmehowto.com/howto/appliance/dishwasher/diagnose-dishwasher.php
05/02/2008 3:58 PM
Cheers,
I've stripped it down as far as I can easilly..I did find a blob of gloop which could have been restricing water flow. The impeller seemed pretty free, I could feel a little free axial play and if I rotated it by hand I could feel it 'cogging' very powerfully...dunno what sort of motor it has, but it had a reassuring feel.
Mrs Cat loaded it less full and it seems to have washed better...it was certainly hot too...so that's ruled out the element element.
I'll leave it now..but next time is plays up it's off the shops (or the interweb) for a new one.
05/02/2008 11:55 PM
Greetings, Del,
Another thing to consider is whether or not you have recently changed the type or amount of soap being used. Not all soaps are equal. We have found that the powdered types work better than do the solid capsule types, at least in our machine. BTW... did you find any cat hair stuck in the impeller?
This is it... so live it up!
05/03/2008 3:08 AM
Haynes do a Dishwasher manual. Might be worth looking before you have to junk the thing.
05/03/2008 3:24 AM
Oh! I thought that was a FIAT PANDA .
Cheers...
05/03/2008 3:31 AM
ROFL !
05/03/2008 3:38 AM
I'm off to Eastbourne...(Christening of great Niece) not back til Monday.
How will I cope with no CR4. I can feel the twitching starting already.
I shall check the sea level when I'm there...
What's the level in your 'bucket of sea water global warming monitor' ?
I could do a calibration check for you ....
Have fun.
(PS Should I mark this Off Topic)
05/03/2008 3:52 AM
The global warming/sea-level detector is still working, but there's something odd going on with the salinity. After a nasty storm, the water level eventually returned to it's initial level, but is now less salty. Maybe I should have used extra samples from high and low tide ? If you take a bucket to Eastbourne, you could bring your own sample of sea-level back to Harlow. Make sure none gets spilt in the car, it would make nonsense of the results.
05/03/2008 4:01 AM
Could this be the discovery of a new desalination technique? Was it an electric storm? Maybe the lightning absorbed the salt.
05/03/2008 4:46 AM
I hope I haven't missed out on a patent here. In the interests of global philanthropy, I'll let this one go. All readers are free to get their own bucket of sea, and use it for back-garden observations. Not only will they be able to make their own contributions to monitoring climate change, but the strange phenomena of desalination I've observed could have huge economic benefits. The technically curious could try standing in the bucket during a lightning storm, though I suggest using a big bucket to avoid spillage. On good days I've woken to find a very useful surplus of desalinated water, certainly enough for a cup of coffee. I've been e-mailing the Met Office with my findings, but for some reason they've stopped responding. Luckily I can walk to the sea to replenish the bucket, but have not yet calculated the benefits for those who have to drive there. If Del seals all the doors on his car, sufficient water could be pumped in to make a return trip to Eastbourne financially viable.
05/03/2008 5:29 AM
For those attempting the empirical approach: in addition to the larger bucket, I believe there are records of an experimentalist who employed a kite secured by a length of cord. This could enhance the effect. I would suggest an inanimate kite, as the Red Kite is a protected species in some countries.
Do you know what kind of car Del has? There was a program on television recently, indicating that the distance covered by a car filled with water is critically dependent on the make and model of the vehicle.
05/03/2008 6:19 AM
If Del gets over-greedy and fill the tank thingy with water, he probably has a broken one. I neglected to advise on whether he should go around the M25 clockwise or anti-clockwise. Doing it the wrong way could result in excess spillage. I heard that Kestrel GTX helps in keeping the thing going, but that's probably only true in the posh areas of London. Being of the feline persuausion, he hopefully has a tiger in the tank.
05/05/2008 6:47 AM
I brought back a bucket of sea water...but when I got home it was empty .
I think the tide must have gone out .
05/05/2008 7:04 PM
If this is the same bucket that you use to fill the dishwasher - I think I have found the problem! The tide isn't the only thing that has gone out.
05/03/2008 12:33 AM
Hi Dell,
Looks like you got it. I'm with Skeeter, next time look for a fur-ball first. Forget the chocolates, get Mrs. cat some cat nip. Mine is always getting the little holes in the spraying arms plugged up so they don't turn, and don't wash everything right. You can't fix it forever, so get her a new one some day. Good luck.
S
Good Answers: 25
05/03/2008 5:24 AM
Hi Del, We are engineers so we always like to strip down ofcourse machines, it is advanture plus we learn some thing even if we break it to peices. So alway we should do our own surgery and if we feel we cant do it then only buy new one or call mechanic. Better to see manual first for trouble shooting instructions it makes job easier.
Good Answers: 18
05/03/2008 9:37 AM
Having recently purchased a new dishwasher after using the prior one for 22+ years, I would make a suggestion that when you purchase a new unit be sure to review such items as the total cycle times and total power consumption per cycle; unfortunately, I did not. My new unit works well, but the cycle times are significantly longer (and hence use more energy per washer load) than the prior model. If i run this unit for another 10+ years the total power consumption will cost me significantly more in total.
05/03/2008 1:23 PM
If you decide to keep the old one, a few tips that I have learnt in 27 years of dishwashers, 7 in all in 4 different houses.....the latest is AEG and only running since easter.
1) Put the plates the opposite way round than you see in the ads, that is the dirty side down. The water jets come from below......many make this mistake! Not too close to each other, some allow a plate in each position, some do not. test.
2) Plumb the machine into the house hot water, hot water from gas or Oil is cheaper than from electricity and even if it comes from electricity, it is warmer quicker, faster. The hot water helps keep the machine internals clean.
3) Use powder only, cheaper and better.
4) Go to a water softener company for the salt, never use salt crystals or powder, only the huge tablets. Cheaper and they last much longer, work just as well and introduce less salt into the environment over the long term. If anyone does not fully understand why, and would like to know why, just ask and I will explain later.
5) Only wash glasses if you have a program for glasses at 45°C or less, otherwise glass may go milky. It also depends on glass quality too.....
6) Take off the larger lumps of food at least before washing.
7) On most machines, you need to make the filter better so that anything the size of a piece of rice or bigger is filtered out of the water and does not circulate through the pump, this means adding extra fine mesh on most machines, even new ones.....some machine filters are so badly designed that they only hold back things the size of building bricks!!!
8) Tune the salt usage down to a minimum if the machine allows.
9) Tune the usage of the liquid that leaves the plates glistening to a minimum. I do not know what you call it in English, the clear liquid.....sorry!!
10) Clean the filter often.
11) Remove the spray arms, go outside, run water though them, clean them out if blocked by food particles, a fiddly job.....I made special tools to help in the process.....if not perfectly clean (see tip about the filter) this will leave food on the plates.
If all else fails, buy a new top AEG, mine is in use since Easter, the best I ever had, good filter and wonderfully and quiet and cleans everything. If you need a model number, just ask.
Good Answers: 93
05/03/2008 3:54 PM
When I was single I washed and cooked, but since I've been married my wife complains if I wash.
things.
Mrs. Cat may or may not like the old dishwasher.
Have you asked her if she wants a new dishwasher, or not?
Time and money will fix any problem that is mechanical.
Do you have an underlying problem?
If there are only two people eating on plates from pots and pans, I really wonder if a dishwasher is worth it at all, since you typically have to wash the sticky stuff off by hand before you put it in the "Autoclave", ie. "dishwasher" regardless of what brand of home residential dishwasher you might buy.
I am interested in knowing really how many dishes per day actually make a dishwasher helpful to all who have or don't. I suspect that really if you have less than 4 people in the house to cook for, a dishwasher is not really much help.
You don't get wise because you got old, you get old because you were wise.
05/03/2008 4:57 PM
I may have been lucky, but with all my dishwashers (7) since 1981 I have never had to do what you seem to need to do. All have washed everything really well. But I do place certain crockery a different way round than shown in most illustrations, its simple common sense, and that does improve the overall quality of the job. See my last post for details.
Experience has shown me that pots and pans with a Teflon finish are ruined in a dishwasher in a short time, so they should not be machine washed.
I must admit I do put pots & pans that are not particularly dirty (provided no Teflon) into the machine, but except for removing large lumps of food, the machine does the rest.
My new AEG is really, really fantastic......it could not be better and is an A A A machine, if you know what that means...?
I would understand your standpoint if I had had a bad machine, I have been lucky.
From the Hygiene side, nothing is better than a dish washer (mechanical not human!!).....
By the way, the trick is not how many people are in the household, but how much crockery and pots etc you have. Even if it takes a day or two to fill up, the results are still better than by hand.
05/03/2008 5:27 PM
Do you know whether anyone's done any studies on energy/water/cleaning product usage for mechanical dishwashers vs the human variety?
I've never had, or really felt the need to have, anything more than a bowl with hot water, some cleaning stuff and a pair of hands.
05/03/2008 5:26 PM
There's some good advice here, but can I add one thing ? Wash it by hand ya lazy *****rd ! Sorry mate, but of all our mod-cons, dishwashers is one of the worst. I can think of scenarios where a dishwasher might be useful/essential, but not many. It's like gas powered televisions - we all got by without them once. Bin the thing and get some marigolds. "Soz" if there's some reason you have to have a dishwasher (I know a few people who do), but get rid of it if you can. I have hours of fun arguing over who does the washing up best, who wastes most hot water etc etc. If you can, get rid of the bugger and put something useful in it's place - home brew kit, dog-box, bath, there's all sorts of possibilities.
05/03/2008 5:30 PM
(Got in there with my thinking 1 minute earlier. Said it more brutally, but better. Have a GA.)
05/03/2008 5:46 PM
PMSL ! You did exactly the same on another thread recently - typed up me answer, hit 'send', only to see your post pop up first ! Still, it's good value for money when we can prod Del with pointy sticks. He's away for the weekend, so I'm going to run before he's back.
05/03/2008 5:35 PM
Hygiene is the main reason for having one, everyone has a fully time job, so laziness is the next reason.....
Also I really hate washing up.
I save in many other areas far more than the yearly running costs of Dish Washer.....
Each to his own!!
05/03/2008 5:49 PM
It takes me 2 paragraphs to get to the truth as well !
That was a lie.
On no, now I'm confused.
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Manufacturing Engineering - Member
Location: Honeydew, South Africa, 26° 04' 50" Lat, 27° 54' 59" Long
05/09/2008 2:13 AM
Hey Kris. Definitely don't want my dog box in the kitchen.
Make The Most Of It.
In reply to #70
05/09/2008 2:24 AM
Me neither - I'd keep putting milk in the dog box, and the dog in the fridge ! At least the cat-dryer is much smaller than all those other kitchen appliances, so mistakes aren't so easily made.
05/03/2008 8:57 PM
1. Make sure that the water coming out of your tap is as hot as possible before you start the dishwasher. That is usually where the water supply to your dishwasher comes off under the sink.
2. Most dishwashers work best at 120 degrees plus Fahrenheit the best.
3. Make sure that you are not stacking any dishes or pans over the middle of the top and bottom rack because that is where the water comes up from the tower.
4. Make sure that the tower does not does not have any material stuck in it or the top is broken off or missing.
5. Make sure that the arm does not have any material in it and moves freely.
6. Make sure that the bottom rack is not put in backwards.
7. Make sure that the arm is moving freely when operating. It should sound like a rhythmic whosh, whosh, whosh. If it doesn't check to make sure that the arm turns freely and isn't brushing against an obstruction when the door is shut. No don't have your friend climb in.
8. If this all is okay then pull out the dishwasher. Lay it on its back (so water won't usually leak out) and look at the pump. Carefully pull apart the parts on the pump and look for a gasket that is misshapen and not sealing, or a diaphragm that is broken.
9. Hopefully you have checked the line and the airgap before all this.
10. If you find a broken part I use Reliable Parts and Part Links through them. Have credit card will mail.
05/04/2008 5:28 AM
That's very good advice. If it's going 'kcher kcher kcher', Del may have mistaken the dishwasher for the washing machine. I made a similar mistake with the cat-dryer once; It left terrible scratches on the enamel. I'm having similar problems with the low level water fountain built alongside the WC.
05/05/2008 6:54 AM
Thanks for all the suggestions everyone...
I don't need to actually 'Consult' Mrs Cat about much...she offers unsolicited direction to all my endeavours without consultation... (she's pretty often right too).
She insists on cramming the dishwasher overfull with lage objects masking eachother from the jets, and carefully aranges tall items to foul the rinse arms.
Gotta hide quick she's coming
05/05/2008 7:29 AM
I am married to the German version!!!!
Except I don't hide!!!
My youngest daughter who still lives with us is almost the same.....
Which is why in our house, I load & unload the dishwasher.....
By the way, for those of you folks who like to hand wash, I did see a study made some years ago in a University in the States (I believe) and the costs were different, hand washing is far cheaper, but not better in many ways (most of which I have forgotten!!), damage to hands if rubber gloves are not worn, cleanliness of items and lack of hygiene being three that I remember......the only way hand washing scored was on price, nothing else!!!
I personally find that (we had 2 months without a dishwasher recently till the new kitchen was installed) the cups are far cleaner (porcelain) and more attractive to drink from when washed by a machine......in fact everything is much cleaner and more attractive....pots pans etc....
As an aside, a similar study with regard to hot air hand dryers against paper hand towels showed that the whole/total cost of both were about equal, but that paper towels had one large and attractive plus, you could also use them to open the toilet door!! As many people do not bother to wash their hands if they feel they are not being observed.......!!! The door handle being the carrier of some mighty germs.....!!!
I do say "each to his own" and I am a confirmed user of such machines....
I also like air conditioned cars for the summer or when it us raining (as it keeps the windows from steaming up even in a cold winter!! many do not know this) and I feel it helps to keep us cool (in both senses of the wood!) in bad traffic situations.
I have an air conditioner for our bedrooms when the summer temperatures go above 35°C (my wife does not like high temps, I personally do not worry I used to live in Singapore!!)...the excess cold air cools the downstairs rooms....Ladies are much nicer when cool!!
Now I expect someone will moan about the fact that we have air conditioning!!! (and lots of other labor saving devices like a Vacuum cleaner, bread making machine etc etc etc!!!)
05/05/2008 12:43 PM
Did the dishwasher vs. handwashing study include energy usage?
05/05/2008 6:30 PM
From memory it included everything, it showed (as I mentioned clearly before) that cost wise hand washing was still the cheapest method.
It included the cost of the electricity, water, etc etc....
Comfort was NOT included!!! I go for comfort!
05/05/2008 6:39 PM
I'm not talking €.
05/06/2008 2:39 AM
The state your case in a better form please, what are you asking about? I will do my best to help you, but I am completely mystified as to what you need to know.
My memory is that the study showed that costs energy, water, time etc., showed that hand washing was the cheapest, but hygiene, due to the temperatures and methods used, sort of fell by the wayside....
05/06/2008 3:08 AM
Andy, I'm trying to get at how much energy is used by a dishwasher, compared with that used by handwashing. I'm not considering the cost in money. Which uses more hot water, and heated to what temperature? What other energy is used?
I guess the energy required to make the dishwasher has to be factored in, as well as the energy used per wash cycle.
As you can't fail to have noticed, energy expenditure is a rather important topic these days.
05/06/2008 3:48 AM
The dishwasher uses far more water (even the modern ones) and far more electricity, mainly in heating the water, but also for running motors and electronics....
A lot of hot water, means a lot more electricity...
On energy costs alone, the DW loses out completely.....plus of course it costs more to buy one etc etc and maintain with salt and other chemicals!!!
05/06/2008 4:01 AM
Thanks - that was my point .
05/06/2008 7:03 PM
Hi Andy,
I have to question this. When washing by hand, the water gets cold, and then you need to refill. That also takes more soap. My hot water is heated by natural gas which is much cheaper than electricity. I have always thought that the DW saved me money. What's this about salt? I have never heard of using salt in a DW. Do you put it in with the soap? And what other chemicals? Rinse agent is all we use besides soap.
S
05/07/2008 7:28 AM
I did not do any of the testing, I only read about it some years ago, my memory is certainly not perfect either, but I would guess that they took all points into account.
For me, the cleanliness and the hygiene side are paramount, I do not think that in any westernized country today, that it is allowed to hand wash plates for customers by hand......I would guess that they have legislation, but I haven't checked, so I could be wrong.....
Salt in Dish Washing machines.
All the DWs that I have ever had, have had a water softener built in, this softener needs salt from time to time to regenerate (Ion exchange process) itself. Maybe some DWs do not need this? Look in the bottom of the machine, is there a big cap (2 1/2 " or so at a guess) that you can unscrew? Maybe the cap has salt marked on it? but maybe you live in a soft water area and therefore do not need it?
The US market is very different in some ways (this could be one) and I have never lived long enough in the USA to find out about this point, sorry.
In reply to #60
05/07/2008 7:16 PM
"All the DWs that I have ever had, have had a water softener built in, this softener needs salt from time to time to regenerate (Ion exchange process) itself."
That makes sense. We have soft water here already, so not needed. I had thoughts of you putting it in with the soap to "sand blast" the pots and pans.
05/07/2008 7:36 PM
....some people like the salty taste......!
In reply to #63
05/08/2008 11:38 AM
You can't say that in a public place Andy!
In reply to #64
05/08/2008 12:00 PM
Andy's one of those former Navy guys, so he probably can !
In reply to #64
05/08/2008 1:35 PM
I did didn't I?
In reply to #66
05/08/2008 1:46 PM
Yes, you most certainly did!
05/05/2008 8:27 AM
Does it have rotating spray arms/bars top and bottom? Check the bushing/seals on the arms for wear. They may be leaking to much and you're not getting enough pressure thru the nozzles. Kept a GE dishwasher going for 10 years. Like you I hate to buy new stuff when you can fix the old stuff. Sometimes you think you've gotten all the crud out of the arms just to have it get back in the nozzles again. Run the dish washer without the spray bars to make sure the piping is clear.
Maybe you'll get another few years out of it..or give it up and spring for a new one!
Good Answers: 42
05/05/2008 2:51 PM
If you have ever had a glass shatter in the machine it does a wonderful job of removing the vanes from the pump impeller. It just grinds them off.
I have had to replace the impeller several times. Replacement kit comes with a new seal for the impeller also.
Messy job, plastic parts that like to strip screw threads etc.. Used a shop vac to extract that last bit of water.
Sometimes it is easier to bite the bullet and buy a new machine.
05/06/2008 2:40 AM
You link is not much use as it requires me to join first.......!!
05/06/2008 2:41 AM
It was a no access...login page
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
05/06/2008 3:17 PM
Sorry about that Del, Andy and anyone else who might have tried that link. I didn't notice the thread was in their archive section, which is restricted to members only. In late 2005, Stormtrack had to migrate to new servers, and whatever was on the old servers was compiled into an archive. I'll post the relevant images later.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Good Answers: 22
05/06/2008 9:47 PM
The image I wanted to post is copyrighted, so I'll link to it here instead.
After the movie Twister came out, stormchasing experienced a boost in popularity. Dorothy, the probe that the chasers in the movie wanted to place in the path of a tornado, was based somewhat on the real-life TOTO (TOtable Tornado Observatory). Some of the new chasers would mount weather stations and other devices on their vehicles. A couple even boasted that they would drive fortified vehicles into tornadoes.
To make fun of these embellishments to equipment and fame, a chaser once took an old washing machine, put a rooftop wind turbine on top of it, gave the thing a fancy paintjob, and called it TAP (not sure what the anagram stands for). The one in the picture is the latest incarnation, and has undergone an upgrade in technology - all the way from a rooftop turbine to a satellite dish!
05/07/2008 2:25 AM
Not many tornadoes in the UK.
I'd love to see one over water....I once got into a confusing conversation with a woman on the South Coast she said she saw a lot of 'em ... eventually I realised she meant the Jet 'Planes...she lived near a fighter base.
In reply to #59
05/07/2008 7:31 AM
LOL
Good Answers: 22
In reply to #59
05/08/2008 4:01 PM
Well, you don't have to make a tornado probe out of it. A satellite maybe? I remember seeing an episode of Last of the Summer Wine where some guy wanted to be an astronaut. Because the UK doesn't have an astronaut training program, he improvised his own. He rode downhill in a 'wheely bin' (trash dumpster here in the US) to 'simulate' the stresses of re-entry. Surely the UK allows improvisations by citizens wishing to explore the world.
I'm sure you can find some surplus devices to mount in or on the old dishwasher to fashion it into a space probe. Maybe the European Space Agency would be interested?
In reply to #68
05/09/2008 7:09 AM
I turned my old microwave into a Primary Radar system (just kidding )
05/09/2008 2:10 AM
Hi Del. In SA we have a little bottle of fluid you buy called cleaning aid. It has a thin waxy film over the mouth of the bottle that you place upside down in your dish washer. You then set the machine to the heaviest, hottest cycle and do a wash with no dishes in. Cleans the machine right out. Had the machine (LG) for 5 years now and still going strong. We just do it once a month with cleaning aid.
Register to Reply 72 comments
3Doug (3); agua_doc (1); Andy Germany (12); Conrads (2); davah (1); GW (1); JohnDG (9); Kris (15); Mr. Truman Brain (3); OlympiaWA (1); ozzb (1); Skeeter (1); StandardsGuy (4); Steve S. (1); stevem (1); suresh sharma (1); Transcendian (1); user-deleted-1105 (13)
