Previous in Forum: Pressure Measurement   Next in Forum: Bently NEVEDA system
Thermowell
05/03/2008 9:08 AM
what is the basic formula to design thermowell insertion lenght?
I need to calculate thermowell insertion lenght for 4000mm pipe. fluid is sea water.
Pathfinder Tags: Thermowell
Good Answers: 54
Re: Thermowell
05/03/2008 10:00 AM
Your pipe is 4000mm in diameter? or is that length?
Usually, you'd want to have the tip of your thermowell at the center of your pipe. Also, it is advisable to have the thermowell inserted at an angle towards the upstream direction.
That's a big pipe, by the way.
Re: Thermowell
05/04/2008 12:38 AM
There are a couple things that you should know:
1. The generally used guideline for immersion in a pipeline is to ensure that the sensitive area is in the center third of the line but no less than 2" into the flowing stream for the full temperature sensitive length.
2. You must check that the thermowell will not fail due to flow induced stress or flow induced vibration. There are resources on the web that can explain these in detail. Search for thermowell strength calculations.
Re: Thermowell
05/25/2008 2:18 PM
As per ASME PTC 19.3,basic guideline is
Fw/Fn should be less than 0.75, if the ratio exceeds 0.75 decrease, U
Fw& Fn depends on flow/operatng temp and pressure ,density and sp volume of material
Some users tend to use the limit value to be 0.8
Fw---wake frewuency
Fn -----natural frequency
U---THE IMMERSION LENGTH,
Regards
Jose John
Register to Reply 3 comments
arnoldp (1); josej (1); Vulcan (1)
