Previous in Forum: Difference between PLC AND DCS ????   Next in Forum: Instrumentation Cables and Communication Systems
Fire Detector System
05/04/2008 3:30 PM
Dear all,
I am supplying fire detectors in one of my project as per client design.
but now client asking more detectors and ask to re-design location of detectors.
could anybody please guide me regarding the detail design of detectors location as per building area??
Nigeria - Member -  Member
Re: Fire Detector System
05/04/2008 5:54 PM
Do you mean smoke detectors?
Where are you installing, an apartment or a warehouse/factory?
This will give a clearer picture for an informed answer.
cheers,
ethobil
Join us to make the world a better place: Propergate peace.
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
05/05/2008 1:35 AM
go through National building code 2005 revised edition published by government of India BIS if you e-mail your id i can send the relevant section of the code for fire protection.i suppose you are located in India
crm
Run silent run deep
05/05/2008 2:33 AM
Dear Sir,
you can mark it on mangeshkakade@gmail.com.
Thanks a lot for your coopration.
Good Answers: 54
05/05/2008 6:22 AM
First things first.
If your client is asking for more detectors and wants to redesign or reassign the locations, you'd better be sure to say that it will cost extra. 'Hope you protected yourself with that clause.
On the subject of detector locations:
Back when I was installing them, the manufacturer usually specified that a particular detector can cover X square meters of ceiling. Therefore, calculating the quantity of detectors is only a matter of knowing the area of the ceiling and the detection area of the detector.
There's a caveat there. If the room's ceiling is divided by beams or floor-to-ceiling shelves or walls, consider each section as a separate space.
Register to Reply 4 comments
crm (1); ethobil (1); mangeshkakade (1); Vulcan (1)
