Previous in Forum: We All Grow Older, But Must We Grow Forgetful, Too?   Next in Forum: DVD Finalizing Not on the Original Recording Device
Evaporator in a Compressed Liquified Gas Line
05/05/2008 7:44 AM
I've an evaporator in a compressed liquefied gas line... i know that evaporator building up pressure, my question is which area should be most critical up stream the line where the evaporator is,or back the line to the CLG stored?
and if it is down stram how i'll ensure i'dont have vapor downstream?
it might be a simple question,
but it is a new experience for me, and really appreciate your help
thank you,
Re: Evaporator in a Compressed Liquified Gas Line
05/06/2008 12:07 AM
Some basic data required:
Is it LPG?
What is the flow rate?
What is the pressure in the (1) storage vessel (2) pipe line, downstream of the vapouriser?
Do you require liquid or vapour at the usage point?
What is the appliance?
N. Mahadevan
05/06/2008 7:54 AM
thanks for your time
Is it LPG? it is chlorine gas not LPG
What is the flow rate? flow rate at application point is around 3000 lbs/day
What is the pressure in the (1) storage vessel (2) pipe line, downstream of the vapouriser? 1-around 100 PSI (2) almost the same
Do you require liquid or vapour at the usage point? Vapour is required
What is the appliance? water disinfiction
