Previous in Forum: Overspray on NEW machines, need solutions for removal   Next in Forum: Minimum pressure to support a flammable atmosphere
caso4 und coagulation
05/09/2008 8:21 PM
hi everybody
i want to know what is the optimal concentration (for activity) of CaSo4 or MgSO4 solutions in Coagulation? Who can me explain???I will be pleasure when i take an answer.
Thank you
Re: caso4 und coagulation
05/10/2008 11:24 PM
The pH of the water solution you are putting it in will influence the coagulation effect and coagulation activity, the level of chelants that are potentially tying up what you may be trying to coagulate, throughput speed and other costs are some key decision parameters that will influence your optimal concentration ranges along with exactly what you are trying to do. If your trying to split highly chelated oils out overfeeding the MgSO4 is ideal..... its not unusual to observe conductivity at this point exceed 30,000 mmhos .... if your trying to split out a heavy metal with a light trace of oils then you might like the CaSO4 and ratios from 500 ppm - 3,000 ppm introduced into a highly agitated solution with a pH below 5.0 pH will usually do the trick for most metal working application splits. Shed some more light on what your trying to do ......
05/11/2008 1:43 AM
The most effective method of removing these charges is mutual coagulation of two colloids whose particles are oppositely charged. Reagents that are able, upon introduction into water, to provoke coagulation of natural colloids are called coagulants.
Some time after introduction of a dose of coagulant into 1 sample, the water becomes turbid.
Turbidity increases with time,
and gradually large flakes form and start settling on the bottom of
uhe vessel, entraining all the impurities. The visible result of
coagulation is the formation of a deposit in the form of porous
gelatinous flakes that settle on the bottom of the vessel. If this is
not observed, no coagulation takes place in the vessel.
In water-treatment practice, ferrous iron sulphate, FeSO4 . 7H20,
aluminium sulphate, A12(S04)3. 18H20, iron chloride, FeC13, are
used as coagulants. They are introduced into water in solutions of
5 to 10 per cent concentration. When a coagulant such as alumi
nium sulphate is introduced into water, it first undergoes hydrolysis
according to the following formula
Al2 (SO4)3 + 6H20 2A1 (OH)3 + 3H2S04
Good Answers: 101
05/13/2008 1:47 AM
I think you're asking about tofu production again. If so, you can get the information you need at this website:
http://www.tofu-recipe.com/make-tofu.html
You can also use 2 tablespoons of vinegar per liter of soybean milk as coagulant.
Register to Reply 3 comments
Anonymous Poster (1); DVader1000 (1); MUKULMAHANT (1)
