Previous in Forum: copper electrolysis   Next in Forum: Liquid Vinyl
How to weld industrial fabrics? Hotseal? Dielectric? Vinyl cement?
05/11/2008 8:10 AM
Industrial fabrics with different substrates(polyester, nylon, etc) embedded between layers of vinyl (PVC), that are joined by sew/stitch them together with the consequence of having holes made by the needle where the water can go through which is not convenient as they are used as covers, tarps, and in general to protect from sun, wind, etc.
Some other methods are to glue them with vinyl cement (i.e HH66), does any body knows of other cements suitable to resist the Marine environment, sun, wind, salt and water?
Look also at hot sealing at http://www.weldmaster.com/weldingtech/ with hot wedge or rollers at http://www.sineqco.com/products/TriadDescription.asp
I heard there is also a Dielectric sealing?
In general all those equipment are costing thousands and thousands of dollars, and I am writing here to try to find affordable methods to seal the thermoplastics in NON-STRAIGHT LINES NON-FLAT SURFACES (Canvas for boats)
Please peruse the two links above, so you can focus only in new information in the forum.
Thanks in advance for your input.
Re: How to weld industrial fabrics? Hot-seal? Dielectric? Vinyl cement?
05/12/2008 10:49 AM
Hi
I have been searching for a way to make vacuum bags for pressing wood veneers onto a sub-straight. I came across the www.ABBEON.com web site the other day, they have a handheld hot air tool that may do exactly what you want (Repairing tarps and awnings and making overlap welds in vinyls and coated fabrics) called the QUICK-LE by Forsthoff (list price at $375.00). A broad range a accessories are available . I don't know much about the company but when I contacted them they called back within a timely manner and where very helpful. Hope this Helps.
BigED
Re: How to weld industrial fabrics? Hotseal? Dielectric? Vinyl cement?
05/12/2008 11:41 AM
Thanks for your help. I think is the same device as the one shown at http://www.wegenerwelding.com/usa/flash/index.html .
We are looking for a similar tool that includes rollers to ad pressure to the welding seam; but the one at Triad is above $10,000 ...which makes it expensive for us; in addition, I think it is not able to do turns for curved lines, and is not suitable for concave or curved surfaces.
...So we keep looking for...
05/12/2008 12:41 PM
The one I was thinking about is a hand-held hot air blower using a tip to suit the width of a a seam you want to create (5, 10, 20, 40mm). At a high heat setting it will melt the plastic between two layers of fabric quite fast. Your not adding any material but melting the material thats already there. Then press the seam by hand. This should be as fast if not faster than applying adhesives since the weld is fast and secure. You can do turns and curves in any direction, make or apply small pieces of fabric for stress areas etc. With accessories this unit is under five hundred dollars. If your making custom, one of a kind boat covers or proto-typing you may want to look into this small unit. It's a place to start and inexpressive way to lessen the cost of your learning curve. Don't just look at their site but give them a call and tell them what you want to do, they may have a better solution. Sorry if this is a little redundant. I just wanted to make sure you were looking at the same unit.
06/02/2008 9:37 AM
Have tried using Ethyl Vinyl Acetate (EVA) low hot melt glue? There are several grades available . It very user friendly, inexpensive, gives fantastic sealing properties especially on fabric surface and offers rapid cure. Application can be by hand held glue gun freely available in the market place. We make extensive use of EVA in our assembly line of carbon filter assembly.
07/08/2008 11:39 PM
Thanks for your help I will try it.
If any body knows of a Welding machine that could be handled as a sewing machine, that would be great.
Any comments for dielectric welding?
Anonymous Poster (1); BigEdm (2); krishnan.ng (1); rlequerica (1)
