Previous in Forum: How to weld industrial fabrics? Hotseal? Dielectric? Vinyl cement?   Next in Forum: US vs China material
Liquid Vinyl
05/11/2008 8:16 AM
There are cushions used in boats that are foam covered with vinyl, there are no seams, no junctions, they are sealed all around.
I am writing to obtain help in how to process the liquid vinyl, where could I find it, and tools tips.
Is same possible with Hypalone
Thanks in advance for your help.
Re: Liquid Vinyl
05/12/2008 3:06 AM
Vinyl responds to thermal welding techniques. Is that how it is assembled, perhaps?
Popular Science - Weaponology - Cardio-7
Re: Liquid Vinyl
05/12/2008 8:32 AM
The vinyl you speak of is generally applied (without seams etc) by dipping into or coating using a solution of PVC, either a plastisol (PVC dissolved in plasticizers) or an organisol (PVC dissolved in solvent). Talk to one of the major PVC manufacturers or simply refer to an encyclopedic , Google, etc. Slush-molded PVC boots etc are typical applications. The plastisol or organisol is solidified generally by heating. Dyes can also be added to the solution etc.
Re: Liquid Vinyl
05/12/2008 8:02 PM
I'm wondering if you are talking about a two step molding process where the foam core is inserted in a mould and the 'vinyl' cover is injected to surround it?
Can you provide a web link that shows such a seat?
Engineering Fields - Automotive Engineering - New Member APIX Pilot Plant Design Project - Member - New Member
Re: Liquid Vinyl
05/13/2008 9:00 AM
most of the seats for boats are formed by vacuum forming a heated vinyl sheet into a mold and letting it cool and take the shape
the cover is then either glued to or urethane foamed behind and then edge wrapped and stapled etc.
Polaris and the industry are moving toward urethane spayed skins which are more durable and more resistant to cold in the case of ski mobiles
if you are trying to repair a hole or tear plastisol can be used
look up vinylpro.com
good luck
Duct tape is like 'The Force'. It has a light side and a dark side and holds the world together.
Register to Reply 4 comments
Cardio07 (1); cbs (1); JE in Chicago (1); PWSlack (1)
