Previous in Forum: Changing the Transmission Fluid in a Dodge Neon   Next in Forum: 7 wire pigtail
Any thoughts about this newscast re water for fuel?
05/16/2008 11:10 PM
I was absolutely dumbfounded when I saw a newscast this week on 'NBC' affiliate KARK Channel 4 here in Arkansas; it is rather obvious that the station never bothered to check with anyone knowledgeable about science, and in fact are no doubt helping this scam to succeed. Check it out: http://arkansasmatters.com/media_player.php?media_id=33607#
I'm afraid that the newscast seems to add some legitimacy to the device as though it actually works and that this is a bona fide business. I'm utterly amazed.
Cheers.
Bill Velek
My personal non-profit project to help humanity - http://www.2plus2is4.com - 'Why our schools should teach our children about grid-computing'
User-tagged by 1 user
Good Answers: 230
Re: Any thoughts about this newscast re water for fuel?
05/17/2008 3:32 AM
Hello billvelek
<"....you can increase your gas mileage up to 35% withjust one simple step....">
<"...You run your engine on Hydrogen....tap water in a Mason Jar....">
<"....mileage increased from 16mpg to 26mpg....">
<"....When the water gets to the combustion chamber, water turns to steam, and you have all these Hydrogen and Oxygen molecules with gasoline, in a very confined space with a spark plug, I don't really see how we can go wrong....">
<"....but it doesn't work for everyone, or some cars because of their computer system....">
Then they say how much it costs....haha, I just knew there was a catch somewhere.
Anyone who gets sucked in by that, is a credulous person, who have not bothered to check a simple Chemistry or Physics book, and who deserves to waste their money.
Kind Regards....
05/17/2008 3:49 AM
You said: "Anyone who gets sucked in by that, is a credulous person, who have not bothered to check a simple Chemistry or Physics book, and who deserves to waste their money."
Well, I feel sorry for some folks, such as the technologically-challenged elderly and some folks who God just didn't bless with much intelligence, so I've sent a letter to a few people to ask that the business be investigated for fraud; I'm a city attorney and local prosecutor, but it's out of my jurisdiction. I just hate to see someone make a bundle of money on something like that. I can't believe the news station didn't bother to check out the science before what can only be described as a huge bit of free advertising.
<>Cheers.
<>Bill Velek
Good Answers: 230
05/17/2008 3:52 AM
Hello again, billvelek
Good for you, that you are prepared to do something about it.
Advise how it turns out, thanks.
Kind Regards....
05/17/2008 4:18 AM
Just to add a simple explanation that lay folk can understand.
The water turns into steam ...yes . But this takes heat (energy) from the combustion.
The Hydrogen and oxygen then burn...yes. Releasing heat (energy) ...but it is exactly the same amount (or less) as was taken in the first place...and it ends up back as water.
To go from water to steam and back to water is hardly going to result in any free energy. Else we'd all be boiling kettles and enjoying the copious free power!
There is evidence that a small amount of water can assist combustion but it isn't actually burning itself.
05/17/2008 5:18 AM
You might be confusing this with the systems that use electrolysis to actually produce some hydrogen (and oxygen); there are a number of them out there, as have been discussed in other threads on this site. That is not the case here; the vendor is claiming, incorrectly, that when water turns into steam, that the chemical bonds between hydrogen and oxygen are broken. I don't believe that that should ever be the case whatsoever; all that is taking place is a simple change in the phase-state. But _IF_ there DOES happen to be some bonds broken during vaporization, I can't imagine that the amount would even be measurable enough to register any change in mileage. And as you said, the energy required to split the hydrogen and oxygen would equal or exceed the amount of energy produced when they recombine. If that were not true, then we would have the makings of a perpetual motion machine. Heck, setting off a nuclear bomb in the ocean would even set it on fire that would sustain itself.
<>Cheers.
<>Bill Velek
Good Answers: 230
05/17/2008 6:41 AM
Hello Del the cat
The only way the water can turn from steam to hydrogen and Oxygen, is by having red-hot-iron inside the combustion chamber.
This method, using red-hot cannon barrels, was used in France, for early Hydrogen-filled balloons.
For a different reaction, please see: http://www.freepatentsonline.com/3615300.html
<"A process for producing a hydrogen-rich gas mixture which is lean in CO and CH4 relative to CO2 which comprises:
A. contacting subdivided carbonaceous matter with steam and oxygen in a reaction zone at temperatures between about 800° F. and 1,350° F. to form H2 and CO2,
B. maintaining the temperatures in the reaction zone within 100° F. of the average temperature for the reaction zone,
C. withdrawing the hydrogen-rich gas mixture from the reaction zone, and
D. feeding sufficient steam to the reaction zone so that the hydrogen-rich gas mixture which is withdrawn from the reaction zone contains at least 60 volume percent steam.">
All the above is quite complex, and energy-consuming.
Please disregard most of the Google advertisements for "energy-saving devices and systems", on that above webpage.
As you say, if the el-cheapo "energy-saving" advertised processes worked, we would be in potential trouble from run-away reactions, in even small quantities of water.
Kind Regards....
05/18/2008 4:11 AM
Both you and Billivek missintrertpret my post...
It is supposed to be a logical debunking of the assertions made in the post to which I was replying, which mentioned the Hydrogen & Oxygen molecules floating about.
I'd have though you'd have worked out by now that I'm not that daft.
05/19/2008 3:46 AM
Sorry, Del. No offense meant. I'm new here and don't know folks. I just thought that you seemed to be acknowledging the presence of hydrogen and oxygen, but were then indicating that it is still a wash (takes more energy from the engine to split the bonds than is yielded during combustion). Of course that is true, but I thought you were relating it mostly because of the other thread which does include the use of electrolysis.
In any event, we're in the same camp, and I'll eventually pick up on your style of writing and your humor.
Bill Velek
05/19/2008 8:30 AM
Cheers... good to have you on board.
Good Answers: 70
05/18/2008 1:14 PM
Hi Del,
Actually when water turns into steam, it is still H2O, the hydrogen and oxygen atoms are still bound together, and there is virtually no free oxygen or hydrogen created. If it were otherwise, boiling water indoors on a gas stove would be dangerous business. The change from liquid water to steam is a phase change, not a chemical change.
The only way that hydrogen from water could ever be a fuel source would be if someone developed a 'magical catalyst' to separate the hydrogen and oxygen. Otherwise the energy required would always be slightly more that produced (due to the inefficiency of any real industrial process). We must hope that no one ever does develop such a catalyst, since it would inevitably escape into the environment, with obvious and devastating results.
Good Answers: 75
05/18/2008 1:21 PM
John:
If Del didn't already know that, and a great deal more, I'll eat my hat. Del has the unfortunate habit of trying to be funny with the wrong audience. Hang around, and you'll really get a whiff of engineering humor. I've been involved in many fields of science and engineering all of my life, since I started studying electronics in 5th grade, and Del teaches me something new, AND gives me a laugh, nearly every time I encounter him. And he DOES know his stuff!!
Go back and check out his post. It was gently sarcastic humor. No foul intended, and certainly Del, even as old as HE is, hasn't slipped that many cogs! Yet!!
Micah
Good Answers: 70
05/18/2008 2:04 PM
Ooops, you're right. Apologies to Del.
Good Answers: 75
05/18/2008 9:15 PM
No sweat on my part, John. Someone has to stick up for him. He's pretty defenseless without it, since he won't say it himself.
Micah
05/18/2008 2:09 PM
Thanks for the vote of confidence ..
Not too sure about 'unfortunate habit' I feel I've been blessed with the ability to see the funny side of life ....
Good Answers: 75
05/18/2008 9:14 PM
Seeing and saying and being understood do not always go hand in hand. Though that IS the desired outcome!
I feel FORtunate (NOT un) to have read many of your more humorous asides. In my case, the UNfortunate part is that while working in my cube farm office, I read some of your stuff and it strikes me so funny I wind up snorting audibly, in one case, snorting my coffee. Scared my cube mates silly.
I LIKE your sense of humor (No I don't. I LOVE it), but what I meant by unfortunate was just that it doesn't always get the understanding it might.
So, no real unfortunate there, unless it's unfortunate timing, or unfortunate targeting.
Micah
05/19/2008 2:45 AM
Now you've made me snort!
Good Answers: 75
05/19/2008 7:55 AM
Oops. Sorry! No pain, I hope (try that with a Coke, sometime).
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
05/18/2008 7:31 AM
Bill,
More power to you.
I also like the way the new 'experts' (drips under pressure, etc) always attach the 'new technology' to the old reciprocating piston engine. They must like the noise.
( I s'pose that's not really fair. We all do. That's why the retro-fit exhaust pipe business is so robust. 'Rev-heads' forever.)
I personally have been on a crusade here to try to expose the 'shonkys' to the general populace. It's a difficult row to hoe. In the end one is effective on a very few, and the populace one is trying to educate generally regards one with suspicion. Every one WANTS to believe in miracles. Don't let a little elementary science get in the way of a good scam. I was further saddened by finding that some of the promoters actually BELIEVED the stuff they were spouting, to utter devastation when they were 'found out'. A sad indictment of the general education system (read: Parenting).
Just a couple of weeks ago an offer arrived via this medium (email) to sell me a system of the type you describe for a "paltry $49.95". 'They' suggested I keep it confidential lest word get out and the rush would be on.
The spread of b......t seems to increasing exponentially. ($$$$$$)
Then there's the comment:" he's only an engineer, what would he know". *o#^%*##.
Keep up the good work.
Cheers,
Stu.
"Nothing, is as it seems." Dr Wally.
05/18/2008 1:48 PM
Gee! And there I go buying about a dozen for Christmas presents!
Good Answers: 70
05/18/2008 1:51 PM
Thanks for intervening to stop this farce. You are right that many people, young and old, have neither the education nor the mental capacity to sort this out for themselves.
However you shouldn't be surprised that the news people didn't check this out. Journalists may be educated people, but their education has not been scientific: to a journalist the concept of 'critical thinking' means at most to report two conflicting points of view with a sense of impartiality and 'fairness'. In this case it simply meant to be careful to use 'multiple sources' for their 'news story'.
That one side of the conflict might be demonstrably correct and the other side pure nonsense isn't something they are taught to consider. Most of them managed to graduate without being required to take any actual science courses. Our universities have 'special' science classes for their 'non science' majors, so they can earn a 'Bachelor of Science' without actually having to know any.
Math and Science are hard, English, History, Journalism, and Social 'Sciences' are easier, don't require actual critical thinking, don't employ empirical testing of ideas, etc.
05/18/2008 2:28 AM
My friend George said when Gas gets to $6 we will find a better fuel.
The engine technologh is here. We will learn how to split water and then I will be one of the happy ones that say to OPEC "Have a Drink!"
The big thing will be for the gov to put a meter on your car and bill you per mile.
The oil companies will have it hard for a while why they find something elso to do.
I give the USA on year records will be set as speed of grouth industuries.
Good Answers: 247
05/18/2008 2:01 PM
We already know how to split water with fairly high efficiency (75%). Even if we split water at 95% efficiency, we still can not get, from burning the H2, any more than 95% of the energy put into the process back out. (Typically, in the US, most of that energy input would come from burning coal.) If we burn the H2 in an internal combustion engine, then we get a small fraction of the energy used to split the water back out: the vast majority goes off as waste heat.
Today, we have car-type personal transportation choices ranging from roughly 10 mpg to almost 50 mpg. Simply choosing to use less energy by driving cars near the 50 mpg end could dramatically reduce our reliance on OPEC, without the need for any R&D whatsoever. If we had really good bike lanes, many of us could bike to work -- also no need for R&D, and there'd be great health benefits.
06/16/2008 5:22 AM
You raise an interesting point. Some of the local politicians are starting to listen, and talk about what will replace the gas tax for road construction and maintenance.
This will become a larger problem as we get cars that burn less fuel.
Politics is one of the problems engineers must deal with one way or the other.
Toll Roads are more common back east - but I have never felt that was a helpful system for society. Restrictions on travel can be political or economic.
Neither fits with our history. Movement is why the Interstate Highway system was built. Moving the Military was the front for a major upgrade to social and economic mobility.
We have a HUGE infrastructure around the TAXES collected from FUEL -
This is a POLITICAL problem that has already affected efficient fuel systems.
rcb
Testing =Testing -Testing -- We create our society each time we interact with another person. What kind of society did you create today. RCB
05/17/2008 9:10 AM
Bill, keep your eyes open, as the price of gas goes higher the scams will be coming at greater and greater frequency...
Good Answers: 18
05/17/2008 5:28 PM
You might think about doing a service for the folks in Arkansas by calling a reporter for KARK and introducing him to a chemist to explain that they have been duped.
WYFF in SC reported something similar several years ago, which I knew was a scam, and which someone later exposed. WYFF tucked their tails and reported that they had been duped.
Stay vigilent!
05/18/2008 12:43 PM
I visited the KARK-4 website forums and found that another poster beat me to the punch and posted a message rebuffing the station and explaining the science, etc., so I added my two cents which included severe criticism of their station for not verifying the facts before airing their broadcast. I presume that someone in their station probably reads their own forums occasionally, and in any event, if something happens on the legal end, they're sure to hear about it. By legal end, I mean that I have sent messages explaining my concerns to the Governor's Office, Attorney General's Office (consumer fraud division), and the Pulaski County Prosecutor's Office (the county were the business is located). I have also asked them to reply to me to advise what they are going to do about it, and if nothing happens, then my next step will be to contact the competiting news stations ('ABC' and 'CBS').
Bill Velek
05/17/2008 9:27 PM
scary.
I'd love to see those guys try to ignite their steam.
05/17/2008 10:43 PM
We might be doing a bigger service to the people of the U.S. by making the oil companies explain why the price of the fuel has skyrocketed in the first place.
Blue
05/18/2008 9:34 AM
1) US dollar devaluation,
2) Increasing worldwide demand, especially China.
3) $125 a barrel oil
4) Restrictions on drilling and on refinery construction in the US
5) Legislation that eliminated MTBE from the fuel stock, and mandated ULSD, both of which reduced supply.
What do you need explained Blue?
05/18/2008 12:48 PM
You can possibly add to that:
No new oil refineries constructed within the U.S. in something like 20 or 30 years (and none planned as far as anyone has revealed), despite RECORD profits by U.S. Oil Companies. I would imagine modernization of refineries would probably reduce price a bit, too.
Bill Velek
05/18/2008 3:15 PM
That is a bit of a misnomer, and even if true it is because the government made it impractical to build a new one.
Granted a new facility has not been built in the last 20 odd years, but lots and lots of refinery expansions and modernization projects have happened in that time period. In addition during that time it became practical to import refined product from other places.
That is why diesel is so expensive. Our government mandated ULSD, US refineries built ULSD capacity, but the other places in the world that we import diesel from did not (Aruba, Venezuela, Mexico) and as a result the US refiners are maxed out on ULSD production, but cannot meet the demand. Therefore the price is $4.50 to $5.00 a gallon. That would drop instantly if Congress repealed the ULSD requirements and allowed truck drivers to use regular Diesel (even for a short time)l.
The Motiva Pt Arthur Texas refinery is going through an expansion right now (construction has begun, particularly the civil work) that takes a very large refinery and more than doubles its capacity (that is in effect equivalent to building a new one I think). And all the majors have similar plans or are executing such projects. Here is a Reuters article with a summary... http://uk.reuters.com/article/oilRpt/idUKN2530030820070925
It is certainly emotionally satisfying to blame the oil companies, but more than a little blame has to roost on your government as well.
It is also easy to accept the mythology, I suggest you go look for yourself.
05/18/2008 5:36 PM
Hess oil in ST Croix build a new refinery in the 1990s, While not in the US it is a US territory. It is the largest refinery in the western hemisphere.
05/18/2008 1:01 AM
Is anyone noticing a pattern here:
1) blond clevage bimbo number one introduces and hypes the fraud, then hands off to;
2) blond clevage bimbo number two, who pushes the fraud with great vigor.
A fraud conspiracy that includes this many people might qualify for RICO prosecution at the federal level.
If it isn't true, why are you repeating it?
05/18/2008 1:37 AM
Don't mean to highjack this thread, but thought I might throw in my recollection of a news report that was broadcast a few years ago. The female reporter was commenting on how a demented fellow was apprehended by police after they lobbed a teargas grenade through a widow. The guy had been holed up with his pet rats in his tiny dwelling, threatening to shoot at whomever tried to capture him. I'm not quite clear on exactly what happened, but I think the guy started a fire inside his dwelling, so the cops quickly resorted to teargas.
The reporter related how the guy was driven from the building, due to the teargas, and went on to say that, "Firemen have said that the rats weren't harmed by the teargas, because rats don't have tear ducts." When I heard that I just about fell off my chair. The reporter was no longer working for the TV station a week later.
This is it... so live it up!
Good Answers: 247
05/18/2008 2:20 AM
It is distressing, isn't it?
This thread from just a couple days ago, is about a similar scam. A Palm Beach TV station "tested" this hydrogen generator, and came up with ludicrous mileage improvement numbers, lending credence to yet another scam. It makes one wonder if the station was paid off. I plan to write to the station, the station owners, and the FCC.
05/18/2008 1:11 PM
Heh, heh. I just visited the website for the Hydro-4000. I haven't studied all of it, but the first scientific flaw I noticed was where the website states: "The engine alternator keeps turning whether or not the engine and battery use all of the electricity it produces. Energy is wasted constantly turning the alternator that is captured to power the HYDRO-4000 which, in turn, produces HYDROGEN AND OXYGEN GASES used to improve combustion. The way modern engines work, powering the HYDRO-4000 is basically free." They either have no clue, or else are hidding it from customers, that the more electricity that is drawn from the alternator, the more resisitance it creates and lags the motor down, requiring more horsepower and therefore more gasoline. They apparently don't know that gas mileage is affected by all of the electrical devices in a vehicle; that's right -- your gas mileage drops when you have your headlights or radio on. That's why it ticks me off that new models have headlights constantly on, even in the middle of the day in the blazing sun; it's supposed to make them more visable and therefore improve safety, but I'll bet the folks who came up with that brilliant idea had no idea at all that it is costing drivers more money and is creating more pollution.
Bill Velek
06/16/2008 6:02 AM
That idea was originated in this land when we had single carriageway roads.
It was to help indicate which way a vehicle was travelling when sighted on the other side of the road. Think of it this way- you dive out from behind a truck to overtake it and you see a pair of red lamps ahead. You're safe. But see a pair of white ones----?
That said, it's all but irrelevant now. The folks in the country on those sorts of roads generally have better manners. And the folks on the freeways don't need to. But they still do. It ticks me off too. Here's me trying like all getout to reduce usage of energy, and these imbeciles run every light on the vehicle, all day. I've actually said to some:" Your fog lamps are on", and the reply is mostly tossed back," Oh , they come on with the ignition". I guess they do when the switch is turned on. Lamebrains!!!
In some states here,it is actually unlawful to have the fog lamps lit when there is no cause for them to be lit. I've asked various road patrol officers why it is tolerated and the stock answer is that to stop the practice is too hard. It should be noted about now that the 'fog' lamps have often been removed in favour of driving lamps. There's a lot of light comes out of those things. I'm forever adjusting the mirrors.
Stu.
05/18/2008 11:43 AM
Check out water wheels too!
Cheers
Vince
05/18/2008 11:57 AM
Hmm...I like the clear container touch. You can see the action right there in the vessel. I feel better already- and wow- just in time with increasing fuel costs. My version of fuel cost savings contraption uses table scraps and old beer cans to produce fusion- and comes in a polished stainless vessel. I understand now I failed to market properly...a website, a clear reaction vessel, and a local news plug. Damn.
It is amazing things like this are broadcast- but a look backwards shows how this will not stop. Humans- we are smart- and we are ignorant. There is a frontal boundary of the two- a storm that brews there.
05/18/2008 1:50 PM
And they say text to speach computers has not been perfected!
05/18/2008 2:42 PM
Origo1 Water Dissociation System
Outlined below is a water dissociation system that does not require electrolysis. It
requires only a photocatalyst, and a source of natural or man-made light. This system recycles its own water byproduct.
Water, of course, is the only portable non-carbon source of renewable fuel available in the huge quantities needed to supplant gasoline. Water requires no investment in exploration, drilling, refining, mining, transportation, service stations, or disposal of nuclear waste. Unlike carbon-based fuels, water is recyclable.
Titanium dioxide is a cheap and plentiful photocatalyst. Dr. Chris Sorrell at the University of New South Wales is working on water dissociation systems using titanium dioxide. (c.sorrell@unsw.edu.au) Australia has 40% of the world's supply of titanium dioxide.
In February, 2007: Dr. Manoranjan Misra of the University of Nevada/Reno, (misra@unr.edu) announced that he had developed carbon nanotubes that dissociate water in the presence of light. He reported that: "The new power source is extremely cost-effective…"
Expensive tris bipyridine ruthenium, reacting in combination with dioctadecyl or dihydrochlolesteryl esters, also dissociates water in the presence of light.
The following Origo1 system consists of a water dissociation chamber connected to a light chamber by optical fibers. The light chamber receives sunlight from a vehicle's roof, hood, and trunk top surfaces. Sunlight is supplemented by a powerful electric light for both overcast daylight and night driving. The dissociation chamber contains photocatalysts and a gas separation system.
Why carry compressed hydrogen at 5,000-10,000 pounds per square inch, as proposed by many, if sufficient hydrogen can be generated by photocatalysts on board a motor vehicle to operate a fuel cell, or an internal combustion engine tailored for hydrogen, or a steam engine?
The light chamber contains a golf-ball-size light bulb, developed by Fusion Lighting of Rockville, Maryland under a U.S. D.O.E. grant. It emits 450,000 lumens when excited by microwaves. A 100-watt light bulb output is 1,690 lumens. The light bulb contains argon gas and a small amount of sulfur. The presence of microwaves makes it necessary to shield the dissociation chamber from the light chamber.
Microwaves are supplied by micro-power impulse radar (MIR), a short-range system small enough to be put on a $10 computer chip, using very little electricity. MIR was developed at the Lawrence Livermore National Laboratory by Tom McEwan, and is available for licensing.
Heat from the light bulb, as well as heat from any fuel cell, internal combustion engine, or steam engine in the system, is conducted by insulated heat pipes to a chamber equipped with thermoacoustic electric generators developed at the U.S. Los Alamos Lab, and with photovoltaic cells that use infrared and visible light to make electricity, such as the 35% efficient solar cells developed by JX Crystals Inc. of Issaquah, Washington.
The more light and area of catalyst to which water is exposed, the greater the quantity of water that can be dissociated within a given time period. This is the key to the whole system. When daylight is directed by optical fibers to power a large area of catalyst, then more hydrogen and oxygen is produced than is needed for the fuel cell, internal combustion engine, or steam engine. Since motor vehicles spend much time parked outdoors, JX solar cells continually charge batteries for night driving, taking advantage of free solar energy.
A honeycombed and well-lighted catalyst can expose water to an acre of area within a volume of a couple of cubic feet. One cubic foot of charcoal, for example, has a surface area of 12.4 square miles. A stable foam is used to contain and support the titanium dioxide catalyst. Solid gas-permeable membranes in the dissociation chamber are used in a gas-separation system.
Catalysts can become contaminated. Since titanium dioxide is inexpensive—it's the stuff that makes paint and toothpaste white—provision is made for changing the catalyst and its support structure, much like changing a vehicle's oil filter. Contaminated catalysts can be recycled and used again.
Electric power for night driving comes from three high-capacity car batteries kept charged by regenerative braking; by excess electricity developed by fuel cells, and by utilization of waste heat and solar energy by the JX solar cells. Batteries sometimes require recharging during periods of prolonged absence of sunlight caused by clouds, or caused by parking vehicles in closed garages during daylight hours. The batteries, of course, supply power for the MIR radar, exciting the argon gas and sulfur in the light bulb to produce its intense light.
A standby system operates the dissociation cycle on a minimum demand basis when vehicles are parked. Also, the standby system eliminates the warm-up time required by current fuel cells, and, in cold weather, it keeps the system water from freezing.
Large, stationary versions of the portable system can be built to provide on-site generation of electricity for individual businesses and homes, thus eliminating the need for large electric generating plants and the millions of miles of transmission wires. Those who can generate their own power will say goodbye forever to high fuel prices and electric power outages caused by grid overloads, downed power lines, or sabotage.
Good Answers: 247
05/18/2008 5:38 PM
Of course, the source of man-made light would have to be off-board, rather than on-board, unless you are intending to propose a perpetual motion machine.
Assuming the source is sunlight, then you could expect 6kWh per day (worldwide average) times the efficiency of the collector x cos 45 degrees (avg. latitude), or about 6000 x .35 x .7 = 1470 watt-hours per day electrical input per horizontal square meter. Assuming 3 sq M collector area, you'd have about 4.5 kWh per day. It would be an extraordinarily light car that could be powered for a meaningful distance on this much energy (this is less that 1/10 the capacity of the Tesla batteries -- and the Tesla is already a small car).
Given the small amount of energy available, it would seem to make sense to simply store the energy in batteries, and run electric motors directly at 90% efficiency, rather than inserting another conversion, and running a fuel cell at 50% and electric motors at 90%.
But in any case, going from sunlight to h2 makes more sense environmentally, than to go from fossil fuels to h2.
A diagram would be a help in getting others to understand your proposed system.
05/19/2008 12:17 PM
Lets do the math for more familiar automotive numbers: 4.5 kw-hours per day is equal to 6.03 horsepower-hours per day. If your daily commute is 30 minutes each way, then you need a car that can make the run (1 hour total) with a 6.03 horesepower engine. Last time I checked, none of the cars being sold today will take you to work and back with a 6.03 horsepower engine. (kW x 1.34 = HP) This little unit could run all day and only make enough hydrogen to get your car to the end of your driveway.
Good Answers: 247
05/19/2008 1:02 PM
And even the 4.5 kWh per day assumes extraordinarily efficient solar cells. If you figure in the losses in going to and from hydrogen (as well as the perpetual motion scheme of using an onboard artificial light to run the H2 generation process at times??!!) you have to wonder if the post was intended to be tongue-in-cheek.
Of course, if the unit ran all day making hydrogen, most of its energy would be consumed in compressing that hydrogen for later use. If the H2 were used in real time, then the car would achieve less than walking speed in the morning and evening commutes, and would run around in circles (tethered, presumably) in the work parking lot midday, for entertainment, I assume.
05/19/2008 1:12 PM
Talking of entertainment...I was thinking of making a little autonomous solar powered vehicle to roam around on my South facing flat roof (ok it faces upwards really but you know what I mean). But as I wouldn't be able to see it it wouldn't be very entertaining...Ha, but maybe if I programmed it to chase the squirrels who use the roof as a short cut...whould that qualify as entertaining?
Whoops I can't believe I just wrote that stuff ... sorry Ken.
06/18/2008 5:20 AM
Ahh lets go back a few years - another thread reminded me of this oldie - Opal GT
electric :)
http://www.motherearthnews.com/Green-Transportation/1979-07-01/An-Amazing-75-MPG-Hybrid-Electic-Car.aspx
The image enlarges when clicked.
enjoy
rcb
Good Answers: 230
In reply to #70
06/19/2008 6:04 AM
Hello rcbondsr
From that Weblink:
<"....As far as the driving range is concerned, Dave points out that-if driven carefully the car can travel unlimited distances (as long as the generator engine continues to function) . . . because of the fact that the motor has a low draw at cruising speeds: only .23 amps at 1,800 RPM. Since the Briggs & Stratton engine turns at a fixed rate and can generate 100 amps at about 28-1/2 volts, normal driving presents no problem.....">
But the Article also shows the diagram above.
Now I can see with my own eyes, and do the Maths too.
The diagram shows 4 in total 12 Volt Automotive Batteries, which gives a Battery Voltage of 54.4 Volts when fully charged.
What this gross error means, is that there is already a major error in the article regarding the Voltage of the Battery Pack, or perhaps nobody proof-read the Article.
Perhaps there are other errors in that Article, not noticed by yourself, of other readers over the years.
These days, of course, the 100 Amp Generator would be replaced with a 100 Amp Alternator, which is far more efficient.
Kind Regards....
05/18/2008 6:30 PM
The local TV station here had a piece on using magnets to increase gas mileage. Of course, the guy who claimed it increased his mileage is selling the kits for about $100. I was gratified when I checked their web site and saw a few emails giving them what-for for not checking it out first.
06/16/2008 3:31 AM
Bill,
This is a POOR example of something REAL.
Start with these links - www.panaceauniversity.org
and then www.smacksboosters.110mb.com for a widely replicated unit that gave me more than 30 % increase in MPG
rcb
Good Answers: 114
06/16/2008 3:44 AM
You don't give up do you!
Why are you here?
Both these sites are BS
No science just ra ra
testimonials aren't proof.
Please peddle your scams on a forum that caters to true belivers or come up with some proof!
06/16/2008 5:11 AM
Garthh,
Statement _ I built and tested both hydroxy ( smack type ) and chemical additives to my gasoline -
I have posted MY results - about a 25% REDUCTION in COST each week.
Query - Have YOU built and TESTED either method of increasing you MPG.
Or do you just believe what you are taught - and never TEST new ideas.
rcb
Testing my way to a 50 MPG Maxima -
Good Answers: 247
06/16/2008 4:49 PM
Any tests I have done confirm scientific expectations.
For example, injecting H2 into the intake air stream of a properly tuned engine reduces power output. This test result squares perfectly with scientific (or educated) expectation. The H2 displaces air, leaving not enough air to fully combust the fuel provided by the carburetor or fuel injection system. Others have found the same result (and you can find university studies that square with the expected result).
Many years ago, I was able to get a lawnmower-sized engine to run briefly on H2/O2 mix from an electrolyzer. The electrolyzer was very large, and the engine would only run at idle, producing no useful power beyond that required to simply overcome friction. (There are YouTube videos of experiments like this, in which the engine runs a little better than mine did, but none in which the engine puts out useful power.) I considered, at the time, putting together a spoof in which I would claim that the engine "ran on water" (whereas it would be obvious to engineers that the engine was running on the battery used to supply the electrolyzer). This was before the days of the Stan Meyer fraud, (or at least I'd never heard of him or attempts to run a car on water). The whole concept seemed completely silly to me then, just as it does now, and not worth spending any time pursuing, although it might have been a fun spoof. Who knows? If I can find the time, I may still do it.
There was nothing in my experience that contradicted science I'd learned in physics classes or chemical engineering school: it appeared that the energy produced in burning the H2/O2 mixture was as predicted by the chemical reaction equations. At the time, I didn't do an energy balance, because the whole thing seemed so silly, but I would expect that the electrolysis was about 60% efficient. The engine ran about as I expected it to, given the energy input from the battery running the electrolyzer (I could just barely get it to start). I'd guess that the overall efficiency was about 5-10 percent. If this were to be self-sustaining (rather than quickly draining a battery) the electrolysis process would have needed to be about 1000% or more efficient. I think we all agree that is impossible.
From BMW's work, we know that cars are less efficient on H2 than on gasoline, and that if we were to run engines efficiently on H2 we would have to redesign the engines to do so. We also know that there is nothing out of the ordinary with H2/O2 mix (in other words, there is no evidence that the hydrogen is mono-atomic or possesses other magic properties often claimed by Brown's gas scammers). This is especially true when the volume of H2 and O2 injected is such a tiny part of the intake air stream: the extra H2 and O2 molecules are just floating around like a few pieces of sand in an ocean.
There is a scooter tested with "HHO" (really H2/O2) which shows no difference whatsoever with or without the electrolyzer connected. The scooter is an ideal test, because the amount of H2/O2 generated could be relatively much larger than in a car (where the energy value is only about 1/1000 of the engine's rated output). The amount of H2/O2 is still infinitesimally small, so we wouldn't expect to see any difference at all, especially in a road test -- and that is what the test demonstrates: "HHO" injection makes no measurable difference.
I've looked at the Panacea University stuff and it seems to be mainly gibberish. Do you have any legitimate sources (SAE, real universities, EPA, Auto manufacturers, physics sites, etc) that support the notion that there is something magical about HHO that falls outside of ordinary combustion science and physics?
06/16/2008 5:54 PM
Ken,
GA.
You have omitted to mention the alternative 'energy' source. That is liquid oxygen.
Develop a national distribution for LIKWIDOX tm. and convert all the cars to run this gas (no air) and we've got it made. The cars will put out so much power they'll be on the verge of meltdown. This will become fashionable with the current crop of youth. They'll be able to skite about achieving 'meltdown' in the 'burnout'. Zingo!
The carmakers will love it. Sell more product as the meltdown rate increases. Everyone wins?????
WHAT!!
What do you mean? Energy used to liquify O2? A mere snip. Not worth thinking about.
Don't forget that it's one of the most abundant elements on the planet. ( LOL)
Just a thought, for when you get some more time and want to have some fun.
Cheers,
Stu
Location: Earth. England/America -the birthplace of the C. S. A. - anywhere I imagine -home.
06/16/2008 4:55 PM
The old HHO scam surfaces again. This is too much fun to ignore. Someone should advise the TV station about it, because if someone buys one of these fakes the station may get sued too.
No technology is so obsolete that it won't work. A stone knife still can kill you as dead as a laser.
06/16/2008 8:00 PM
The Model T was run on hydrogen in 1933 - with an electrolytic carburater - looks like you have one of the vintage to try it on - patent is at the much maligned PanaceaUniversity.
Good Answers: 114
06/16/2008 9:16 PM
Please feel free to post your results in detail!
Make, model, year, miles & use of your test power plant.
MPG on gas, propane Or diesel
conditions of operation: temperature, route, wind speed & humidity
total miles traveled & amount consumed.
State of charge of the battery before & after
Repeat with your device in operation.
If I were making the sort of claims you are, I would provide the above at a minimum.
I have no interest in spending my hard earned money to try & prove our collective point.
Read what Ken has written & the thread(s) he linked.
[did I miss anything?]
06/16/2008 10:30 PM
GA - Garthh - I absolutely support the submission of independent testing and definitive proof. If they can prove it works just as they claim, then good. If not, then they need to stop trying to sell it until they can prove it.
06/16/2008 11:24 PM
Do NOTE - I am NOT SELLING anything - I am reporting that some opinions expressed here DO NOT reflect REALITY as I have TESTED it.
Get over your whining -
rcb
Good Answers: 114
06/17/2008 12:06 AM
I'm interested in facts & reality.
What would lead us to believe your opinion reflects facts or reality?
When you have some feel free to share when you have some of either.
06/17/2008 12:41 AM
I am TESTING - what are you DOING
bye
Good Answers: 230
In reply to #59
06/17/2008 12:46 AM
Hello rcbondsr
<"....I am TESTING - what are you DOING....">
I am researching, also trying to prevent you both wasting a non-renewable amount of your lifespan, at the same time hoping that you don't make a fool of yourself here, and require this sign
Tests, to be true tests, must by their very nature, be truly verifiable by independent researchers and test laboratories.
I trust you don't take offence, I do have your best interests at heart.
Kind Regards....
06/17/2008 12:54 AM
LOL - Thanks Sparky -
I do tend to get on my SoapBox now and then - especially when folks tell me that what I am doing is "Wrong" or "NOT REAL"
All this is MY RESULTS - - I will continue to Share REAL results - those who want to think it is NOT REAL - I can not help -
You post was a great reminder -
Thank You
rcb
Testing - Testing - Testing
06/17/2008 10:40 PM
rcbondsr - What is so wrong about this? "I absolutely support the submission of independent testing and definitive proof. If they can prove it works just as they claim, then good. If not, then they need to stop trying to sell it until they can prove it." I believe the article broadcast was about a device that someone was selling or at least promoting. The "they" referred to those people. I did not say you were selling them. In addition I find it strange that you replied to my comment when all I did was agree with Garthh. Why not jump on him?
I have no objection to all the anecdotal evidence anyone wants to give, but it is not proof. Some people have too much fun with their anecdotal reports and assume they are proof. I am not calling them liars, but I will only be convinced that HHO works when there are impartial independent tests and a rigorous scientific explanation of exactly how it works. If it really works, provably, that's good. If not, then go back and tinker with it some more, perhaps a breakthrough will happen.
In reply to #64
06/18/2008 2:48 AM
My apology for my mistake - -
rcb
Good Answers: 114
In reply to #59
06/17/2008 2:24 AM
I'm Breaking ground on a new biodiesel production plant. Gathering as much used vegetable oil from as many places as possible.
I do plenty of testing, trying to improve our methods & reduce costs. The fuel we make has undergoes periodic 3rd party testing & passes ASTM specs.
Unfortunately our neighbors burned down our chemical storage & fab shop, office, electrical service.....
I gather plenty of data & run various tests. I have to do more than hold up a sample & proclaim it good.
When people ask I try to help them make informed decisions about using biodiesel.
Example: I would never suggest someone with an 25 year old pickup start off using 100% bio [2-5% & watching the hoses & filters]. I always try to provide as much information as people want [usually too much].
Good Answers: 230
06/17/2008 12:40 AM
Hello rcbondsr
Imagination, coupled with personal opinion, is surely a wonderful thing.
Sadly, nothing you have said, nor the links you list, contain independently verifiable facts and truth.
Sincerity of belief is never a substitute for truth.
Kind Regards....
06/17/2008 12:46 AM
Verifiable ?? YOU can verify the things I report - no third party needed for an ENGINEERING group. I provided Links to the Plans I used - If your OPINION is that it HAS to be WRONG - PROVE IT - TESTING IS THE ANSWER
Obviously blinded by opinion - Engineers TEST - mechanics follow other folks plans.
rcb
In reply to #60
06/17/2008 11:23 PM
rcbondsr - No, it is not for each of us to verify by building or buying an HHO device and trying it for ourselves. It is not for us to prove our opinion is right or wrong. It is up to those people who believe it works to get a respected independent unbiased body to test it and definitively answer the question for the rest of us.
Some people believe in faith healing and some don't, but when a group of doctors confirms the total overnight healing, complete with before and after X-rays, MRIs, CAT scans and other tests, then even unbelievers begin to doubt their unbelief. Do the equivalent with HHO and the same will happen. Have the independent tests, get the scientific explanation of how it works in detail, then no one can doubt it.
Stay in your rant from atop the soapbox and you will be dismissed as just another crackpot. I am sure you want to be believed, so take the steps needed to be so. Anger and frustration at the disbelief of others is harmful to you. God bless.
In reply to #65
06/18/2008 2:52 AM
My objection is that several folks here are expressing opinions as if they were FACTS -
Stating that someone who reports that "anecdotal evidence" is wrong WITHOUT testing
is not helpful to EITHER party.
I know the results of my tests each time I fill up - If you do not wish to reduce your consumption - ignore my reports. BUT do not claim that I do not know how much gas I am burning per mile -
rcb
Good Answers: 114
In reply to #67
06/18/2008 3:36 AM
Please expand upon that.
You keep repeating the same vague claims on this & other threads.
Put up or..............
still waiting for facts!
In reply to #68
06/18/2008 4:34 AM
1992 Ford F350 200k - historical average 7.5 mpg / with hydroxy 10 mpg
1985 subaru gl 300k - historical average 20 mpg / with hydroxy 27 mpg
Starting test on 93 Nissan - Historical record 24 mpg -
using chemical additives - claims are 10 to 60 % - testing will tell
Folks working on these problems report a wide range of results.
How well maintained is the engine - are you driving a consistant route - using the same brand of gas - do you actually PRACTICE filling up the same way at the same pump -
Some people are better at this sort of thing - some - are still trying -
Hydroxy is a problem for the newer cars ( except maybe flex-fuel ) because the
system is designed to achieve a certain level of O in the exhaust - Hydroxy ABOVE a certain (variable) amount increases the O in the exhaust - the computer adds fuel to "correct" the balance of the system. -
No conspiricy here - simple problem of different algorithms trying to solve the same problem, and getting in each others way.
Add to that a complex regulatory system - and the problem is less easily solved.
My Senator has been helpful in dealing with the EPA - but it is not a SIMPLE fix for the complex of regulations we have stacked up.
IF we could get a "Straight Forward" system to add to each vehicle - and got the MEDIAN savings reported by folks who have been doing this for a while -
RASH STATEMENT AHEAD
We could reduce the FUEL consumed in this country by 25% within 12 month, at a cost of about $300 per vehicle.
Several groups are working on the various parts of this puzzle.
I will continue to provide my anecdotal notes here from time to time.
rcb
Good Answers: 247
In reply to #69
06/18/2008 12:09 PM
Hi rcbondsr:
Given the mileage numbers you've provided, you can probably understand how rational people would be skeptical. The original EPA numbers for the largest engine, automatic transmission F250 (granted, slightly lighter than your truck) were 12 city, 16 hwy for 13 combined. The new numbers for this truck are 11 city, 15 hwy for 12 combined. On average, respondents to the EPA site achieve figures closer to the older numbers than the newer numbers -- but the respondents are probably a little more interested in fuel efficiency than the population at large, so the new numbers are probably close for most people. The F350 is not rated by the EPA, but it would be reasonable to assume figures 10% worse, or about 11 mpg combined. Some magazine road tests have achieved figures of 10 mpg for crew cab F350s even heavier than yours. Thus, the "with hydroxy" number you quote seems about right for a standard truck. It would suggest that the hydroxy has no effect at all.
Your Subaru was originally rated 26 city, 32 hwy, 28 combined. The new ratings would be 23 city, 29 hwy, 25 combined. Thus, again, your "with hydroxy" numbers seem about right for a standard Subaru. I owned a Subaru GL of your vintage, and routinely achieved the original EPA combined figure, while living in upstate New York. Getting down around 20 mpg would require some really extraordinary driving. You can probably understand how your figures do not ring true.
But consider other tests. WPTV tested a Dodge Durango and got 9.4 mpg without oxyhydrogen and 23.2 mpg with: about 2.5 times farther on each gallon of gas. They even "used" a dynamometer to get these figures. They will be redoing the tests (which are obviously flawed, because a Durango does not ordinarily get 9.4 mpg), under the guidance of Dr Abtahi of Florida Atlantic University. It will be interesting to see their new results.
As you probably know, simply injecting hydrogen into the intake airstream would not be expected to have any beneficial effect, and dynamometer tests show that power output is reduced, in concert with conventional science. (The H2 displaces air, leaving insufficient air for combustion of the injected fuel.) Injecting both H2 and O2 could be expected to compensate for the power reduction caused by air displacement, by supplying enough additional O2 to at least combust the tiny amount of H2 produced by electrolysis. You'd still, of course, expect a net loss, because the oxyhydrogen is produced at a huge net loss, and to break even on energy, it would have to be produced at 500% efficiency, which I assume you agree is impossible.
Your "before" figures are clearly extraordinarily low. Can you supply any theoretical explanation for why there would be any measurable change from oxyhydrogen injection? Bona fide dynamometer test results would help us to believe you, too. You may very well believe that onboard electrolysis improves your mileage, but you can probably understand that we are no more likely to believe that is does than we are to believe someone's claim that a magnet strapped to a fuel line would have any influence on fuel efficiency. Providing a theoretical basis might help bolster your case.
Your belief that real engineers simply begin testing without first researching the theoretical basis for their work is simply wrong. A goal of engineering is to be able to create structures and products based on what we "know" will happen, based on the applicable science. Thus, the civil engineer does not cringe in fear when the first truck rolls across his bridge, and the structural engineer does not loose sleep when his building is subjected to its first storm. If we all simply went off on flyers all the time, testing one highly improbable concept after another, we'd still be in the stone age.
I recently dropped a quartz crystal into my gas tank and my fuel efficiency increased by 55%. If you don't believe it, then prove I'm wrong.
What do you think is causing your incredible efficiency gains? Measurement error? Placebo effect? Some effect unknown to science? There has been a 75 year history of onboard electrolysis scams, with several high profile cases of fraud conviction. Perhaps you can give us some shred of evidence or at least a theoretical basis to think that you are not just another fraudster? We are here to help you avoid damaging your reputation, and are encouraging you to come up with something (anything!) scientifically plausible: even if you could come up with a theory that would explain how 100 watts worth of anything (let alone ordinary H2/02 mix) would make a measurable change in the performance of an engine rated at 100,000 or 200,000 watts, we'd love to hear it.
If there is merit to your contention that using water as fuel can improve mileage, then we'd like to help you lobby the automakers to use such a sytems on their vehicles: imagine how thrilled Ford would be to stem the flow of red ink as their F150 sales have dried up! Imagine how silly Toyota will feel -- they spent billions on the Prius to gain only 30% over a conventional car of equal weight and aerodynamics. In mass production, these electrolyzers could be a $30 addition to any car! And there's no R&D to do -- these thing have been around for decades!
Even the Hydro 4000 site says "With these products energy in must equal energy out, so they just don't work!" (http://www.hydro4000.com/faq.htm) This assessment comes straight from one of the promoters of your technology. So....?
Is there something you can say to give us hope?
In reply to #72
06/18/2008 1:09 PM
Great post Ken -
The quote at the bottom is Hydro4000 claiming OTHER systems do not work -
I do not know anyone who has one - The amperage drawn is lower than I expect for units producing 2 to 3 LPM ?? I am interested in the design, and will try to find their patent pending material.
The TV station test is interesting also - the mileage at the start is also BELOW epa ratings. They are re-testing and expect to update in July - I have bookmarked the page -
My F350 with 460 was acquired with blow head gaskets - and over-heated enough to change the color of several cylinders - at 212,000 Miles I replaced the Head Gaskets,
- and went back to driving - not a bad $700 truck but the mileage was 7 1/2 = I have done nothing else to the truck but test Hydroxy and Chemical additives -
MPG started with 3,000 to 4,000 miles of history - from my reciepts - I keep them and write the mileage on each one.
The Subaru was bought for $160 at 296,000 miles - not running - I got it running and drove it for about 4000 miles before starting my experiments - again NOT CHANGING any thing except what I am testing -
The Nissan I am testing now has about 210,000 and the history from the previous driver said 24 to 26 - I got 24 on my first tank - added some chemicals - and am still driving.
Hope - is mostly INTERNAL - my path is LISTEN to everyone and TEST the things that I can afford to test -
I started a thread about Jarboes Mill - check it out - I can not go - but Several Devices will be in one place with the designers and builders there to talk to.
Lots of things SEEM unlikely - that are real - been there - got the scars -
I am not going to rebuild old beat up engines to get them to spec. - Just run them as they are and see what happens when I change something that I CAN change - and REPORT to rest of the folks that can INFLUENCE the next design.
I still have quotes from SWI for testing my engine design, and after it is running will wind up paying someone like them to test it. -
MEANWHILE I test what I can as I can -
Fuel systems can give 50% boost - so I will work on them while finishing my engine, and try to get to 150 MPG instead of 100 -
Hope - is internal - you have to decide to deal with the world -
I stayed out of politics after Nam - now I see the error of that choice.
Transportation systems I CAN provide CHOICES for - and shall.
Be Well - Keep Testing
rcb
In reply to #72
06/19/2008 12:26 AM
GA, Ken. You said it much better than I was able to.
Good Answers: 247
In reply to #74
06/19/2008 4:05 PM
Thanks.
If you haven't already, you should look at this site on the Hydro4000. A month ago, Jamie Holmes, the reporter for WPTV (clicking on his pick at the bottom of the page takes you to the report) wrote to say that the Hydro 4000 people did not have his permission to use his picture, and that he had talked to management at his station. But a month later, his picture is still there, appearing to endorse the product. Hmmm.
Before too long, the retest will be done. It will be interesting to see how it comes out.
In reply to #79
06/19/2008 4:46 PM
Badly I expect - That is not a well done system -
For a real package look at www.hydrogen-boost.com
or www.smacksboosters.110mb.com
BOTH of which are KNOWN to work by the Hydroxy Community.
Their are always frauds around money and NEW "applications" for consumers.
I have no way to tell everyone HOW to DISCRIMINATE -
My TESTING shows that the sites above DO what they SAY.
rcb
In reply to #69
06/20/2008 8:19 PM
CHEERS MATE.......I for one am in complete agreement with you.
Working on one myself. May start a forum to compair results when it is working on line in my S10, 1995 with 156k......
Onward............
06/18/2008 9:52 AM
If you are going to talk about a carburetor, please use the correct spelling of the word.
In reply to #71
06/19/2008 12:56 AM
if you are going to post with concern. please do so as a contributing member.
Good Answers: 230
06/19/2008 6:30 AM
Hello rcbondsr
There is no such thing as an "Electrolytic Carburettor", except one referred as that in a Patent - Refer: http://www.free-energy-info.co.uk/PatE8.pdf
Please note the final sentence on that Patent: <"....Manifestly, the construction shown is capable of considerable modification and such modification as considered within the scope and meaning of the appended claims is also considered within the spirit and intent of the invention....">
Of course, on that .PDF document, no claims are appended.
The drawings are well-done and pretty to look at.
I do note that the "Pole Changer", as shown, is totally unnecessary, although it does add to the complexity of that carburettor, and may well fool those who do not properly understand basic Chemistry and/or Physics.
I also note that for the water in the carburettor to be conductive, Sulphuric Acid is added, thus with a fast and fizzing electrolysis continuing, (It has to, so that enough Hydrogen and Oxygen can be made to run any engine, even a small one), Sulphuric Acid mist will inevitably be drawn up from the surface of the liquid and that Sulphuric Acid mist will be drawn into the cylinders of the engine, corroding it quite quickly, along with the exhaust system, and anyone who stands too close to the exhaust outlet. (Don't sniff the exhaust gases, you will ruin your breathing apparatus).
I have used correct spelling for "Carburettor".
There are Electrolytic Capacitors, which are very different.
There are Electrolytic Cells, also different, and please note that even a successful Patent Application does not mean the Patented object is properly effective.
Kind Regards....
In reply to #77
06/19/2008 3:09 PM
Thank You
I am a bit sloppy with the spelling at times -
That carburettor was demonstrated on a Model T - worked as described.
The inventor was a city engineer for Dallas, designed the traffic light system we use today, and he and his son built the carburettor.
The pole changer probably came from Tesla - though that is pure speculation. Several people were trying to "break water" and other interesting things, and had a fairly active correspondence.
I often wonder what future archaeologists will work from - all these electrons will vanish, with even less evidence of their existence.
Be Well
rcb
06/20/2008 1:04 AM
Yea, and I bet you believe in Global Warming!!!!!!!
Why is it every time running a car on Hydrogn brings out he de_bunkers, like honey draws flies?
You know it works, I know it works, you must work for or have some vested interest in keeping this technology from being developed....
When I hear guys like you, I think thee protest to much, makes me even more sure it works
Geez, guess we cant send a lander to Mars, to far away.........
Good Answers: 247
#82
In reply to #81
06/20/2008 11:51 AM
This is an excellent example of the value of conventional science. No scientists educated in the subject matter were saying we could not send a lander to Mars. Some people uneducated in the subject matter were stating such things because they were clueless regarding the many areas of science involved.
The same sort of people, uneducated in the subject matter, are saying, now, that perpetual motion schemes work, despite no evidence that they can, and a huge volume of science indicating that they cannot and do not.
Instead of providing drivel, maybe you could make a useful contribution by explaining the physics, chemistry and combustion science that would make this perpetual motion scheme work (in a physical sense, not just in the sense that the scam works to separate people from their money).
There are several excellent university engine labs in the US and elsewhere. If you can provide links to papers from university studies that support your view, that would bolster your case for perpetual motion machines. In the early space age days there were literally thousands of scholarly papers indicating that, of course, a Mars lander is feasible -- so feasible, in fact, that the subject matter of (again) thousands of these papers had to do with best ways to achieve various goals. If perpetual motion is viable, and if you are just "ahead of the curve" in understanding how it might be accomplished, then perhaps for the benefit of mankind, you could share links to the thousands of scholarly papers that must support your notion. Just as there were thousands of papers supporting landing on Mars, there should be thousands supporting your contention, right?
Without such evidence, I think you'll have a hard time convincing many people here (and, in fact, would have a hard time convincing a bright middle schooler) that perpetual motion schemes work as advertised.
Obviously, cars can and do run on hydrogen. No credible source debunks that notion. The debunkers come out when the perpetual motion scheme of running a car on water is promoted. The reason they come out is because they have an appreciation for civil law and hate to see gullible people bilked by frauds. One can argue that such people deserve to be fleeced, and that if they are stupid enough to believe such drivel, then making them poor might reduce the likelihood that they will reproduce, generally benefiting the species. But to me, and to many others, that seems a little cruel. Many of these people, uneducated in the physics, still make loads of valuable contributions in other areas.
In reply to #82
Re: Any thoughts about this newscast re water for fuel?
06/20/2008 5:58 PM
Ken,
GA from here.
Stu
In reply to #82
06/21/2008 4:17 AM
Dear Ken,
I do not look at this as a perpetual motion machine. I may have the definition of perpetual motion all wrong, but, I feel pretty sure you may give me a lesson.
we are looking for a hydrogen generator small enough to run one automobile, using a larger alternator and an moderately sized battery or two, connected to a properly constructed fuel cell.
I do believe trying to have hydrogen fueling stations like current gas stations will never happen.
Sorry bud, I think maybe you should subscribe to the KISS theory on this one.
By the way, Google Wright Bros. propeller, they were way ahead, earlier I forgot to say build one by hand today as efficient. But, of course the builder today already knows it can be done, just reference the Wright Bros.
Man, you are just to smart for me, I need to hang with the folks with dirt, blood and cuts, that are to stupid to be working on something that is working right in front of them. I guess, what they are seeing is a figment.
I am just now beginning to believe that if one cannot see or even allow himself to believe by way of the experimentation going on, sans giant grants.
Comes down to this.....If you cant dazzle them with brilliance, baffle them with BS!
Maybe give me a run down on overhauling a v6, 30 valve, twin overhead variable cam timing, electronic fuel injected fully drive by wire engine.....You do that, I may be impressed. I would be the same as me understanding most of the stuff you write about my post.
Give us a break, Talk at my level, sounds like a doctor telling me my diagnosis and not having a clue what he said. I know its hard for you, just give it a whirl.....
Also, we are schemers. Sure hope you are not subscribing to the biggest scheme of all Barrak Hussien Obama.......and we cannot forget the Nobel Prize winning Al (cardboard man) Gore. This cycle is worse than having a root canal without novacain, cocaine, morphine, or something to kill the pain. Sorry!
Need to keep it clean here.....
Looking forward to the reply. By the way what do you do as a profession? Don't answer if it is to personal, just interested. No matter what anyone says, good or critical, I always look for the few things I can learn and take with me...
See ya,
In reply to #88
06/21/2008 10:18 AM
Hi RiverRat,
Mayby I can help bridge the gap between the greasemonkeys and the eggheads.
My 2002 Isuzu Axiom 2wd v6 2.5l makes 230 hp without needing 2 intake and 3
exhaust valves, but it is drive-by-wire and coil-on-plug. After letting a
"friend" drive my 63 Studebaker, straight-6 auto 1/2 ton zip-van, I had
to rebuild the engine. Took me about 2 months. I know there are things
we can do to our cars that will boost 1) horsepower, 2) torque, 3) gas
mileage. I added 1/2 cup of fuelinjector cleaner to a tank of gas a few
months ago and got 5% better mileage. I added 3 psi to my tires when they
were low and got 3% better mileage. If I add a turbo, I can boost all 3:
power, torque and mileage. Scientist and engineers have completely
explained how all these tricks work.
You got better mileage by making
the change you describe, but without having an engineer study the
before and after combustion process inside your engine, we don't know
exactly what is going on inside the cylinders. Did you pull the heads
before and after and mic the cylinders? Check for rough patches?
Deposits?
Without these kind of before-and-after facts, we are all just guessing.
Good Answers: 247
#90
In reply to #88
06/21/2008 1:41 PM
Hi RiverRat:
Our experience is probably closer than you might think. I started twisting wrenches on my own stuff when I was 12, and by 15 was working as a professional mechanic before I could legally do test drives. Funny that you should mention rebuilding a V6. I've rebuilt many VW and Porsche flat fours and several Porsche flat sixes. I've rebuilt at least one V4 (from a Saab) several V8's, 2 or 3 V12 Ferraris, many straight fours, several twin cam straight sixes from Jaguars, and loads of 1,2, and 4 cylinder motorcycle engines. I don't remember ever having rebuilt a V6 though. I owned a Citroen with a Maserati four cam V6 for a few years, but never rebuilt it.
I've designed and built a couple motorcycle chassis dynamometers and have taught both motorcycle and auto mechanics in a technical school. I was a halfway competent motorcycle road racer for a while (I think Kenny Roberts could blow past me if he was on a 50cc bike and I was on a 750cc, but otherwise I could keep up with the next group down -- people who were sponsored but not making millions) and I was the head mechanic for a professional motocross team.
I've done lots of other gear head stuff, and some consulting with big corporations, but still, what makes me tick is the gasoline running through my veins, and I'd rather be in the shop welding something up than sitting at this computer.
On the other hand, I've had a lot of teachers and mentors who are scientists, and they've been a huge help in pursuing some of the weirder stuff I've done. When I was building a wing-powered sailboat to go after the world record for speed sailing, an aerodynamicist at Cornell quickly straightened out some misconceptions, and put me in touch with a well-known aerodynamicist at Stanford who supplied me with a computer program for analyzing and designing wing shapes. Even with help from these mentors, this was a long project, but without them, I'd have been recreating stuff done before the Wright brothers and by hundreds of scientists since.
My current project is shown in my avatar. There's more here: www.gaiatransport.com.
Re perpetual motion: Some perpetual motion machines are simple and you might think it would be obvious that they do not work. But some pretty smart people have been sucked into playing with these things. The Museum of Unworkable Devices has loads of examples and explanations. For some devices, you really have to do the math associated with the leverages involved to see that the device will not work as planned. For some of the machines that rotate, you can see how it would seem like it should work in one direction... but then you look again, and you can see how it would work equally well in the other.
Cars that run on water are less simple, but a lot further from actually working -- they are actually extreme cases of perpetual motion machines. Many mechanical perpetual motion machines will coast for a long time, because they are very carefully constructed, with the inventor thinking that all he has to do is just get the friction lower, and the thing will work. Cars that "run on water" however have much higher losses: the engine looses 75% of the energy content of the fuel, typically. The alternator looses about 30% of the mechanical energy from the engine. So in one revolution, you've lost about 80% or more of the energy to make the next revolution work. So, the electrolyzer would need to generate 5 times as much energy in H2 as the input energy, just to break even -- just to keep the engine and electrolyzer running, without putting out any extra hp to actually run the car. We know, from millions of examples of the way things work in nature that that is impossible.
As Simanek points out in his site (the museum) some of these schemes are harder to debunk than others.
Many of the proposers of water for fuel, magnet motors, Perendev motors, etc who have visited CR4 are true scammers, in it for the bucks. I know you are not in that class. There is no harm in experimenting, and somewhere else on this site I mentioned putting together a spoof re running a car on water, and 99% of journalists would fall for it, without realizing the the car is being propelled by the battery*, and before long, the battery would be dead.
When engineers talk about this stuff, we can assume a fairly strong background in physics, a strong background in math, and some background in chemistry. Therefore, it is a little difficult to keep things simple, and I am probably not succeeding here. Please don't take it as condescending -- it can be hard to find a common language.
Some things you can google: Laws of thermodynamics, work-energy equivalence. conservation of energy, energy balance, perpetual motion machines, etc. If you scan down this article to "Automotive" you can see that this stuff is generally considered fraudulent.
*for instance one kilowatt hour in the battery produces .75 kilowatt hours of hydrogen, which runs the engine, which provides (25% of that 75%) 190 kWh of energy to run the car and turn the alternator. But the alternator has to produce one kilowatt hour to keep just the process going, and with only 190 watts left powering it it cannot so so.
In reply to #90
06/21/2008 4:56 PM
Hi Ken,
Just thought I'd point out the typo before anyone gets confused:
"which provides (25% of that 75%) 190 kWh of energy to run the car"
should be:
which provides (25% of that 75%) 190 Wh of energy to run the car
Cheers,
TG
Good Answers: 247
#92
In reply to #91
06/21/2008 6:50 PM
Good catch! A factor of 1000 can make a big difference in the energy balance.
Good Answers: 70
#93
In reply to #92
06/22/2008 12:21 PM
I think these are not perpetual motion machines (duh) - they are a special type of electric car. A normal electric car uses batteries to run an electric motor. These new cars use batteries to split water in to hydrogen and oxygen, and then burn the hydrogen in an internal combustion engine (what do they do with the oxygen?).
Engine efficiency is pretty far outside of my area, but I'm inclined to agree that trying to burn two different fuels (hydrogen and gasoline) in the same engine at the same time is a loser: an engine designed and tuned to burn one efficiently will not be tuned to burn the other.
Again this is way outside my comfort zone, but based on my profound ignorance I can imagine that with careful electrode design it might be possible to make an electrolysis system for splitting water that would be extremely efficient (since I don't know much of anything I'll bet it could be 75% efficient).
So now in my dreams I see an IC engine designed specifically to burn hydrogen. Because the fuel is homogeneous (not a mixture of similar molecules as is the case with gasoline), the combustion in more complete and the engine is more efficient. In fact (since this is my dream) it turns out that this new hydrogen burning engine is 51% efficient, while the best electric motor is only 38% (this is still my dream). So in this scenario the battery-electrolysis-combustion engine would be the winner with 75% x 51% = 38.25% efficiency.
In reply to #93
06/23/2008 1:25 AM
Well, depending on the type of device you are speaking of, some of them ARE purporting to provide perpetual motion. For instance, the type of device I was speaking about originally (I started this thread) does not rely on electrolysis or the input of any energy at all (I'm not going to quibble over the energy needed to suck air through a mason jar of water), so it is NOT a perpetual motion machine. And by the way, there is some evidence that it actually can, in some circumstances, slightly enhance mileage because the water vapor can have an affect on speed of combustion similar to using fuel having higher octane; my main greviances were that the science used to explain it was all wrong, the mileage improvements were surely greatly exaggerated, the device can cause damage to the vehicle yet warranties are most probably voided, and the scammers promoting this nonsense are charging their clueless victims hundreds of dollars for less than five bucks worth of hardware and a line full of bull-sh_t.
Now, if a system simply uses a battery which is charged at home, etc., and the battery provides electrolysis for the hydrogen needed for internal combustion (a HUGE ineffeciency compared to just using the battery for an electric motor), there there is no claim of perpetual motion there, either. But if the device is for the purpose of adding more power (to get more mileage) to the vehicle by using any of the electricity it generates for the electrolysis needed to produce the hydrogen, as I _THINK_ you are suggesting, then that device IS for perpetual motion (duhhhh) because, in a nutshell, they would necessarily have to be providing more energy than they consume (surely you will agree that if it were just the opposite -- that the device would consume more energy than it would provide -- then it would not be perpertual motion nor would it be desireable to use in any vehicle).
Now let's look at the device. If it really works, then once it is running we should be able to disconnect the battery and eliminate that from further consideration so that we would have an engine running on hydrogen generated by electrolysis from the electricity provided by the alternator driven by the engine. We should be able to take the exhaust (100% water vapor) and cool it down into pure water which would be returned to the electrolysis unit to replace the exact same amount of water which was just used to produce that much exhaust. So we would then have a closed system where no water is ever lost; a system which simply vents the exhaust and instead relies on a tank of water (like a gas tank) still operates on the same principle, and both systems would be perpetual motion machines.
Even if it were somehow possible to miraculously achieve 100% efficiency (no lost energy due to noise and vibrations, or heat loss (including infra red) and friction -- wind resistance against moving parts outside the engine as well as internal friction in the engine, belt and pulleys, electrical resistance in the wiring, and any engine support mechanisms such as water pump and oil pump -- it doesn't do any good unless it can provide energy for its intended purpose (powering a vehicle), and that means that it MUST provide more energy out than energy that goes in -- perpetual motion. By the way, you probably don't realize that if you draw current from an alternator to power a 1 horsepower electric motor, that the opposing magnetic force that the flow of current creates in the alternator is going to be 1 horsepower (assuming a 100% efficient system). People who come up with (or fall for) these schemes don't seem to understand that very simple principle of physics; instead, they think the alternator is spinning so why not use the 'free' energy it could provide. They don't realize that the more energy that is drawn from the alternator, that the harder it is to turn the alternator. That is a FACT!!!
Therefore, it is IMPOSSIBLE for your system to work.
Bill Velek
My personal non-profit project to help humanity - http://www.2plus2is4.com - 'Why our schools should teach our children about grid-computing'
Good Answers: 114
#95
In reply to #94
06/23/2008 2:58 AM
Let's consider The economic ramifications.
Assuming this stuff works.
Why would the major vendors Delco, moog, bosch,nipondenso, hatiachi, seimens.... or even Ford, GM, Mopar pass up the money to be made? Any of these companies could easily use their vast resources & connections to fly through the legal & regulatory hoops. No for profit will pass up easy money & it would be easy money, if it worked........................................................
In reply to #94
06/23/2008 3:39 AM
The reaction in the combustion chamber is easily shown to change by measuring the exhaust gases.
Emissions are regularly show to decrease. - enough reason to use one for me.
Mileage increases more than 10% in more than 1/2 the vehicles with no additional electronics added.
Actual experience and testing trumps theory and calculation - at least for those of us who buy gas at the pump.
rcb
Testing =Testing -Testing -- We create our society each time we interact with another person. What kind of society did you create today. RCB
Good Answers: 114
#97
In reply to #96
06/23/2008 4:47 AM
Still Waiting for details of the
Results, Results, Results
Good Answers: 70
#98
In reply to #94
06/23/2008 12:13 PM
I agree that the mason jar device from the TV new story is almost certainly a scam. The claims have been sufficiently debunked in this discussion. I'm sure that there will be some engines that are so badly tuned (maybe sparking too early) that the presence of water vapor actually makes a small improvement in efficiency by slowing down the combustion by a few milliseconds. Any small increase in efficiency in these cars will probably be offset by the cars that performed worse.
As I said this is well outside my comfort zone. But it does seem to me that electrolysis is the type of process that could be made very efficient - no moving parts except the electrons, ions and bubbles. So my suggestion was that it might be possible to combine a very efficient system for hydrolysis and a very efficient hydrogen engine (maybe a turbine) that will have a combined efficiency greater than an electric motor (which if I had to guess is probably is the 30 to 40% range). You state however that this would be a HUGE inefficiency, and if that is the fact then it's good enough for me.
I don't have any illusions about perpetual motion. My question was about whether there is a more efficient system to get power from the batteries to the wheels than an electric motor.
Good Answers: 247
#99
In reply to #98
06/23/2008 2:09 PM
A typical electric motor is 80% efficient. A highly efficient electric motor, powered through a highly efficient controller can be 93-94% efficient, including controller losses. LiIon batteries are typically over 90% efficient, so with today's technology, efficiency from plug to wheel can be 85% or so.
The figure you mentioned earlier of 75% eff for electrolysis is very close, with highly efficient systems getting around 80%. 35% efficiency for an engine powered by hydrogen would be considered very high for a diesel, and much higher than you could reasonably achieve with a spark ignition engine. so tomorrows tech battery-to-hydrogen-to-engine efficiency would be about (90% x 80% x 35%) 25%, much lower than 85%.
However, even this is not what is proposed in the water-for-fuel scams. In these, the battery is of starting size -- large enough to power a car for a distance measured in feet or meters. Therefor the energy for electrolysis must come from the engine, through the alternator. With current technology, this means that the efficiency of the electrolysis portion must be about 500% simply to sustain the process, let alone to produce any usable power. In other words, that amount of H2/O2 fuel produced is 1/5 of that to simple allow the engine to sit their idling, let alone to actually move the car.
Water-for-fuel mileage improvement scams are a variation on this, in which the energy from the hydrogen and oxygen is 1/5 that used to create the mixture. Promoters claim that there is some magical effect by which this H2/O2, (typically 1/1000 to 1/100 the total fuel injected) fundamentally changes the thermodynamics of the engine. There is no university-level research which indicates that this is the case. The expectation is that the mileage should be reduced slightly, but the energy used (and H2/O2 produced) is so slight as to be unmeasurable.
Good Answers: 75
#100
In reply to #99
06/23/2008 2:41 PM
Ken, Del, all of you guys, I follow the formulae and equations to a Tee, and understand the physics of it all, but it leaves me with a question about WWII history as I have often read it, never seeing any statement debunking what I've read. That concerns water injection to aircraft piston engines, in order to generate a power level called (at least in my reading) "Wartime Emergency Power". Supposedly, a short period of water injection let the engine produce 4-8% more power (the numbers were never clear, but the extra speed they supposedly gave the prop planes would account for about that much extra power) at the cost of greatly over-heating an engine. So it would enable the plane to outrun pursuit, and limp home the rest of the way, at the cost of an engine teardown and rebuild.
Stupid question time. Was it all hokum? I'm beginning to think it had to be.
Mike
Good Answers: 247
#101
In reply to #100
06/23/2008 3:17 PM
No, not hokum at all.
The water injection would permit higher power without detonation, which can be extremely destructive. Modern car engines are designed to tolerate light detonation (and have knock sensors that adjust injection and ignition to eliminate it if it starts). Older aircraft engines did not have such fancy stuff.
In a modern turbo engine, boost is electronically controlled to make the torque curve perfectly flat. If you lower the octane of the fuel (in engines in which high octane is required, the system reduces torque (and consequently HP) to prevent engine damage from detonation. Restoring the engine to high octane will permit the engine to make more power (and I'd guess 5% might be about the increase). If you didn't have high octane sitting around, then using water injection with one of today's turbo engines would have about the same effect as it did in water injection aircraft engines: it permits higher cylinder pressures without incurring detonation.
Most normally aspirated engines do not require high octane, and, in them, water injection should have little effect, although if injected at the right point could cool the intake charge, possibly increasing power a little. Injecting water could also cool the sensor in most mass airflow sensors, which would be read as greater air mass, and which would cause mixture enrichening, which would increase power a little. However, when the engine is running in closed loop mode, the O2 sensor would bring the mixture back to stoichiometric. So the engine might produce a little more power when cool, (before warm enough for closed loop operation) but emissions would increase during this phase.
Good Answers: 75
#102
In reply to #101
06/23/2008 3:29 PM
Ken:
Thanks. I gave you a "good answer" on that one. I never was clear on WHY that should work, but understood that it did (if I hadn't read it wrong, anyway), so it's good to know not only why, but how, and what the limitations are. So, I guess, if you had to run 12.5 to compression or greater (shaved heads, pop-up pistons, stoker crank, etc.) and only had a lower octane gas available, you could do that with water injection, to at least allow for transit of the affected vehicle, until you could get it to where you either a) had higher octane fuel available, or b) could park it till more favorable running conditions could be found.
But I guess if you had that situation, you could save a potential (and costly) engine rebuild by trailering it, or even having it shipped, from a to b.
Mike
Good Answers: 70
#103
In reply to #99
06/23/2008 6:30 PM
Thanks for the info. Its obvious that the water as fuel is a scam. And now with your numbers it's clear that hydrolysis/hydrogen combustion is far less efficient than an electric motor. I've got to say that I'm surprised that electric motors are so efficient.
Anonymous Poster (4); Bill (1); billvelek (7); Blink (13); fliptop427 (1); Garthh (7); GroundedinScience (1); JE in Chicago (2); jmart23 (3); johnfotl (6); micahd02 (6); Origo (1); rcbondsr (17); RiverRat (3); Skeeter (1); Sparkstation (7); Steve S. (3); Stueywright (4); Taganan (6); TomGearing (4); user-deleted-1105 (6)
Previous in Forum: Changing the Transmission Fluid in a Dodge Neon   Next in Forum: 7 wire pigtail
