Previous in Forum: Material Clarification - Reg   Next in Forum: Pressure Rating
Tank faberication&Erection
05/18/2008 5:25 AM
Dear Sir, i need detail of tank faberication& erection of 8m dia and 8m hight
Re: Tank faberication&Erection
05/18/2008 10:56 PM
What details you need. Probably, except the wall thickness calculations, your fabricator will guide you about everything.
Re: Tank fabrication
05/19/2008 2:33 AM
If your fluid is hydrocarbon, I advise you to buy a current copy of API 650 " Welded Steel Tanks for Oil Storage". And if your fluid is water, please refer to AWWA standards. Note: For water storage you can apply the API 650 also.
05/19/2008 2:36 AM
First, finalize your requirements such as process fluid, operating temperature, operating ressure, pressure direction, installtion detail, expected service life etc.
Second, select a designer and a fabricator.
Third, Test the tank as per applicable service condition.
Man Mohan Pandey
04/28/2011 7:36 AM
Very curious ... Cialis helps to say better than Viagra and Levitra stronger.
grreep@gmail.com
Abdel Halim Galala (1); gsuhas (1); mm_pandey (1); user-deleted-47 (1)
