Previous in Forum: hi i ma having problem with Rs485   Next in Forum: How to Select Thermal Relief Valves
Dry Contacts vs. Wet Contacts
05/20/2008 4:44 AM
Hi,
Can anybody tell me the difference between Dry & Wet contact?? And what are the application of both type of contact????
Re: dRY & wET cONTACT??
05/20/2008 7:40 AM
Dry Contact typically uses relay contact (just terminology difference)
where as wet contact uses 110 vac or 24 vdc mostly used
mosly dry contact are used in the MCC side ,some EPC do use wet contact
r u from mumb ?
regards
jose
01/13/2009 4:18 AM
hi josej
I have a level switch which is using 24VDC as its power and its output is in term of contacts NO and NC. It is E&H level switch with model # Liquicap M FTI 51.WILL YOU CALL IT DRY OR WET??
Re: Dry Contacts vs. Wet Contacts
01/13/2009 12:11 PM
Common (c) you connect to 24 vdc supply or 110 vdc supply depending upon you bus bar /Input module .
NO/NC You connect to your channel or Input point
This arrangement is called Dry/Pot Free contact
Regards
Jose
04/19/2024 7:13 AM
Yes. Internet search engines can. Mentors at the facility can. AI Copilot can.
Register to Reply 4 comments
Anonymous Poster (1); josej (1); PWSlack (1); RAJ KUMAR (1)
